Hmm. I bet the switch is in the latch. IDk if it would work on a prius specifically, but I've heard of folks tieing rope to the latch loop on the hatch and using a screw driver or something to push the rope into the latch, locking the rope in and holding the hatch down with the rope. If the latch is engaged that might turn off the chime. I may have tried it once.. don't remember. Just one of those bits of knowledge I tuck away in case I get in a bind.
For me though I've upgraded to roof rack if I'm too lazy to hitch up the harbor freight trailer. That trailer has come in so handy for many years. For a few hundred bucks it turns your car into a pickup truck with an extremely low, easy to load, deck height. It takes all the abuse of hauling instead of roughing up an expensive truck or the interior of your car.
Gotta be careful with those 4' Menards shelves. I buy a lot of them - most of my builds these days use - and noticed sometimes they have 11-1/4 widths, and sometimes 11-1/2. I have also seen 5/8 material mixed in. It is varying quality PB sometimes. All in all, well worth the coin with some pickiness.
Use one of their tape measures to be you get the right size and go through the stacks to pick to good ones. I got home with some one time and one of the boards had a 1/32" rabbit on one edge. I should have looked closer at the store.
Everything Peerless by Tymphany in bulk and available - they have 4,400 DA25TX00-08 corundum tweeters in stock too . . . and a few XXLS subs and . . . ooh!
I was about to post that. Not a lot that interested me on clearance, however the PM180-8 is being discontinued and is on clearance for $60 so with the discount code will be $45. I already have them, and kind of a niche driver, but that's an awfully good price.
Just snagged a quad of the PM180s for absolutely no reason. Had to use my personal account to use the code though as the business account wouldn't accept the coupon.
Same on my (Hybrid) Highlander. I've driven pretty far with the hatch ajar just a bit with boards in the back and the alarm going off the whole time.
Yeah it's Menards so....
Most cars have a pin switch, pull it and short the wires problem solved, it will see the hatch as closed.
https://www.micro-semiconductor.com/manufacturers/Peerless-by-Tymphany
Just an FYI.
Ships from Hong Kong.
https://www.jfcomponents.com/
Please remember this is RFQ
Not sure if ebay is breaking rules (no seller affiliation). HF108 for $90
https://www.ebay.com/itm/334808579008?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=eVHy0cdnRNm&sssrc=2349624&ssuid=eoLfsU3iRFq&var=&widget_ver=artemis&media=SMS
Man if I were building any PA stuff right now.
Thanks.! I bought a couple. I sold my MTM 15’s so I can build something nicer now.
Somebody just got a rockin set of units.
You said rockin and units in the same sentence. Hehe snicker*
Wonder where that sales at?
Is this a Parts Express sale. It says nowhere on that ad where it’s from.
It's Parts Express.
https://parts-express.com/promodisplay/D
https://theelectronicgoldmine.com/collections/speakers/products/g26929
Ford dome tweeter for $5
Can someone else try and see if the code works on their end?
Same issue when I try...
So basically they are full of shit.
Worked for me. $89.97 for a pair of PM180's
Did you use all caps for CINCO23?
Just have to go to checkout and it applies the discount. Glitchy website these days.
These days???
I guess it has been shitty for several years now.
No.! I refuse.
Ditto!
I ordered a RS225 to cut slits in Scan style. I'll see what happens to an aluminum cone.
