Thanks for the write-up, Don! I've been struggling with Hornresp and this paper clears up some of the problems I was having trying to get this program to create a stuffed ML-TL. In your ML-TL example, I noticed that when Hornresp created your ML-TL model, it was using a "Closed Mouth Horn Loudspeaker Wizard." So, that is why I could not add stuffing to my ML-TL models in Hornresp. I was trying to create an ML-TL using the wrong wizard. Look forward to your tapered TL simulation, when you have it ready.
Thanks buddy.
It took me a while, but I feel that that Input Wizard is the key way to start any project.
Never had success trying to turn one model into another.
I will send out the tapered TL update in a few days.
Peace and Love!
So can it fo my enclosure? So far I only see having both top and bottom taper. Can I make the bottom line flat and the top angled? Is it always driver and port facing like the schematic is? Like can you send the driver/port to the top line?
Hornresp might be able to model your box shape, but what I suggest is to model a 2 segment tapered TL.
You know what you want for VAS and Fb, shoot for a 10:1 or 8:1 ratio closed end to open end. Then you figure out folding the line. For your box, probably one fold will work.
I wrote a short python program that would give me the cross section area (CSA) and tunnel "depth" for every centimeter of the length. From there, it was easy to fold the modeled line into my desired box.
Don't worry a whole lot over some of the non-square angles in your box, unless it really messes with the line CSA somewhere.
I'm not doing an actual TL, MLTL is what I'm talking about. I'm just trying to predict the best port placement. The box shape and woofer location is set.
ok - do you need help in setting the offset of the port? It's pretty obscure in the program.
Or geometry? How long is your line compared to the height of your box?
It's just a ported box. It gave me an option for 3 or 4 segments, I chose 3. I then entered S1 as the bottom, S2 as the wide point (unfortunately it defaults the woofer there) , S3 I made Auto, S4 is the top. S23 moves the port. I can't move the woofer because it moves the wide point of my enclosure.
@rjj45 said:
Pretty sure MMD in Hornresp = MMS in T/S list
MMd is the total moving mass of the speaker while MMs is MMd plus the mass of the air in front of the cone. The relationship formula is
Mmd = Mms - (8/3)rhoRd^3 = Mms - 0.0032667* Rd^3
where rho = density of air = = 0.001225 g/cm3 and Rd = effective piston radius in cm
If you're a DATS user you can use the above formula with your driver's published MMs to determine MMd. Then you can use the DATS "Specified M(md)" method to calculate Vas. No need to build a test box or add weight to the driver cone to reduce Fs.
Please export the Hornresp record for this design and post it here (it will be a small text file)
I'll see what I can do. Looks like you can make S2 long and S3 short(er), which will move the port down.
WoW - That ^ doc is quite comprehensive, Sir!
Thanks for putting it together.
Thanks buddy.
Peace and Love!
V2 - added tapered TLs
I received a request to overlay or compare F3, F6, and F10.
So I'm not getting the schematic layout like your tutorial? I only get the layout, none of the sliders and stuff?
Also, do these driver parameters look like they are entered correctly? I used my measured Le and Re, not sure what Mmd is?
Ok, I see the "Loudspeaker Wizard"
I went straight to calculate, not to Tools first.
I'm not sure about how (or if it will) model my box shape. Possible?
Yep, you end up doing a LOT of work in the wizard.
T/S parameters
I'll try to upload the file when I get home.
