Sugrivans - 2 way R176 TL and XT25BG60-04 in Visaton WG
124»
  • @rjj45 said:
    Continuing in my exploration of terminus "mid" leakage.
    I've got several more TL experiments planned once I finish these.
    The 'leakage' as show from ~200 upward in your graphs look much better behaved with the fiberglass. With the extension down towards 28Hz for the line design I'd be very happy (but then would consider using my miniDSP to trim down the peaks).
    Thanks buddy -
    I popped in a test crossover this afternoon and played some music. Bass is pretty impressive for a 176mm driver, but I already knew that from other Rival 176 builds.
    A miniDSP would not help in this instance, the frequency response from the drivers is nice and flat. The problem is what happens to the back side radiation and out the terminus.
    Coming up, I've got an identical box, but with a removable side so I can alter the plenum behavior - I'm thjinking that perhaps lining the plenum with 1/2 inch foam will kill the leakage and resonance.
  • Interesting set of measurements, Don! Looks like it is simply the longest line dimension that keeps reflecting back no matter what you do with reasonable amounts of stuffing along the line or elsewhere. That was my conclusion as well with my dual chamber experimental transmission line project. I tried very hard to solve the problem, cut came up empty. Good luck at trying to find a solution! :+1:
  • I like your foam idea and the removeable sides. I have been thinking lately that I should make a test box with removeable sides and document the results of what I've discovered so far.
    Point taken (line response). But then there is the total / net room response (listening area) of the combined outputs. Guessing much smoother than just the line - and impressive low end extension from the line, with a bit less steep drop than a ported system ?
    Yeah - that terminus will be on the back side, so much of the >200Hz sound will be mitigated naturally.
    Bass on TLs is something I'm still investigating. At best, it usually measures (standard sweep) just like the ported box model, but to me (and others), it just sounds better. May be woofer damping by the stuffing or tone burst behavior. But I like the sound. Can go deeper than a ported box without unloading.
    Steve_Leetajanes
  • Jeez - you never know when life will get in the way. After the last update here, we bought a house, then had months of contractor work. Finally got back to finishing the crossover on these.
    First, the unfinished, untrimmed baffle on the unfinished box.
    and fast forward to the somewhat finished design during measurements today:
    Birch baffle finished with water based poly - and teak veneer on the carcass:
    EggguySteve_Lee6thplanetjhollanderugly_wooferkenrhodes4thtryGowaTurn2tajanesand 3 others.
  • edited August 2024
    I literally wasted months trying to use ARTA to make dual channel measurements for input to Vituicad. I had continued problems with ARTA (never figured that out), and just dropped back to Omnimic and knocked it out in short order.
    Originally i had the perception that the bass was just a little light. Modified my first test crossover to give about 4 dB or BSC and everything came together.
    Four basic curves:
    I worked at tuning a nice reverse null, and in the process created a classic BBC dip:
    I actually really like this sound, prevents any glaring in the midrange
    Steve_Lee4thtry
  • Crossover came together pretty quickly.
    Normalized horizontal polars:
  • Impressions:
    Very smooth, very clean, very detailed. All my torture tracks show no issues.
    Steve_LeeGowatajanes
  • Those look fantastic! Great work!
  • Sharp units!!
  • Really nice job! Looks cool too. Bonus!
  • Thanks guys. I had not used the XT25 beast mode or a waveguide before, and I like both.
    The Rival, of course is powerful and detailed.
    I always feel nonplussed when imaging cosmetic choices, glad y'all like them.
  • Love that tweeter. Much better than the OG XT25, which is no slouch.
  • SO I've been working on these on and off for the last year, and was never really satisfied by some aspects. First off, the bass was not what I have come to expect from the Rival R176 woofers, so I dialed in more BSC with a 4.0mH inductor and solved that. But no matter how I played with the crossover, something just wasn't "right" in the midrange/lower treble. Ran some more horizontal polars and "oh heck", found something.
    So I wondered if that slightly darker red band around 2K was a problem. Yep it was!
    Here are the individual measurements.
    Oh, (effing) no, the off axis response is peaking above the on axis. Not good.
    So this baffle has a mitered edge.
    I am SO hoping that putting a 3/4 inch roundover will solve this problem!
    I will update this thread once I cut it.
  • edited June 2025
    So all the time I've been working on a crossover for this, there was a dip at 1K. I thought (foolishly) that it might be baffle related. Finally I pulled out the other one of the pair, and suddenly noticed that it had a "B" written on the box. So "B" stock. Ran another FR measurement with the NEW woofer and it was just like the first one.
    and OF COURSE DATS shows edge termination issues at 800Hz.
    So it looks like these 2 woofers are the first candidates for slit cone experiment.
    I think I have 6 more Rival R176 woofers with various cones in the storage unit.
    Shoulda checked them when they arrived....
