1…2122242627…36
  • Usually a speaker event inspires my next next build. I come up with something super challenging then later regret it.
    a4eaudiorjj45PWRRYDSteve_Leetajanesugly_wooferScottSjr@mac
  • When you're in liquidation mode you don't have that problem. I've gifted, donated or sold 4 projects so far in March. I'm going to gut another project and move the better drivers to some better cabinets and then redo the Relayers for a more WAF look and feel. In the meantime I hope to donate or gift a couple more pairs and may even have a few decent drivers to run to a bargain bin sale. IF I can stay on a roll.
  • @Eggguy said:
    I would like to see you steal my idea of a WTWW 2.5 way with MAC06's all in parallel
    The issue with this is impedance. The upper midbass being used higher is not the problem, but that it still is used in the bass range. If you use it strictly as a mid, it is much easier to get a good impedance result and several 3 ways have been built with 3 woofers. 3 in parallel will not be a good load at all being they are 4 ohms alone. In this case the woofers would have to be wired in series.
    Some more thoughts to the 2.5way layout...
    If you connect the lower pair in series to make that pair 8 ohms, you still parallel with the 4 ohm midbass making 2.6 ohms net before xover parasitics.
    There will be no net sensitivity increase by having the 3rd woofer, not only because of the series wiring, but also related to the 2.5way arrangement. However, the impedance will be better having the 3rd woofer in series present by paralleling 4 with 8 instead of 4 with 4.
    The other issue is power handling and applied voltage. The midbass and woofer pair will receive the same voltage, making the midbass play louder and maybe run into mechanical issues before the pair would.
    This still being a 2.6 ohm load is the main issue for me, but will have oter problems to sort out.
    It is always better to have all drivers in the same range in parallel or in series for the voltage reasons. If wanting all in parallel, then the woofers really should be at least 8 ohms using lowpass resistance to compensate, or 10 to 16 ohms to make the load safer.
    While I applaud your excitement and drive, I would call the premised show stopped.
  • The 6" MAC are 8 ohm, but yes still will run into impedance issues.
  • edited March 2024
    Okay, my mistake. Thank you for the correction. For some reason I thought all of the MAC were 4 ohms.
    To elaborate further then, the 3x 8 would still be 2.3 ohms. The series woofers would still help in the impedance, but the voltage differential would still cause issues.
    I agree with this part.
    That describes far too many of my builds. :p
    jr@macjhollander
  • edited March 2024
    But.. isn’t that the challenge/ fun of trying something new each time we go out and ‘make sawdust’ ?
  • The mac06 has a Zmin just below 8.4 Ohms. That's more like a 9 Ohm driver. It has a couple of decibels of built in BSC. Put those two in parallel MTM style with a third woofer adding 3 or 4 Db. additional BSC. With some series DCR from inductors and I think Zmin might only dip to 2.9 Ohms around 200-220 HZ
    Steve_Leejr@macScottS
  • I prefer amps that can handle that.
    6thplanetrjj45Tom_S
  • @kenrhodes said:
    I would like to see what you come up with for a GRS 8PT-8 PA speaker. Pair that with something like the pro dt175 and a 60x60 horn could make a nice pa/monitor.
    Did that already.
    kenrhodesSteve_Leeugly_woofer6thplanet
  • Is that the JF tweeter? Sealed or ported? Looks like a great HT build.
  • Yes JF tweeter in my fiberglass Seos8 horns. Ported around 65Hz if I remember correctly.
  • Nice! Cool build thanks for sharing.
  • Little commercial speaker listening.
  • They look pretty nice, some of my first speakers were Jamo. Going to through them in front of the microphone?
    Yep.
  • Nice large port.
  • edited April 2024
    Really digging the GRS MTM. I bet they would be pretty killer towers... Some extra volume to coax more bottom end. I have a pair of those 8" I tried in the Tuxedo T-shirts but they didn't work out with the high crossover point so I used the PA200 instead.
  • edited April 2024
    Would it be OK to use the total coat bed liner over the Benjamin Moore primer?
    Or would it be better to apply it directly over the plywood?
  • You can put it over the top of primer. I do it all the time.
    Silver1omo
  • Almost sad most of these will be stripped for parts and Throwing away.
    Turn2
  • Which ones and why? Maybe list them if something is useful to someone (me?)
  • Any of the things I will have for Sale will be on our Pre-Parts page on the website.
    https://www.jfcomponents.com/pre-parts
    ani_101
  • I don't see any speakers in the photo listed in on the website Pre-Parts page. Is that coming up?
  • Listings and pics show up on my phone
