My Grandma and Grandpa had that same table in their kitchen (or at least very close to it) . Can't count how many meals I must have eaten on it. Saturday morning biscuits and gravy.... great memories of them.
Sunday I stacked 9ft deltas with 98ft tails. Started flurrying while I was out there. Yep, I'm a dork lol.
But there was another couple out there from the local kite club with a 14ft flow tail delta. So I wasn't the only dork!
Oh yeah, nothing but proper gasket tape these days. I stocked up on some good stuff from McMaster for like $30.
The port tube in question was this guy. I hate that spline fitment, and I'm never sure it's 100% seated. So out comes the rope caulk and an X-acto to trim the squeeze out.
@Steve_Lee said:
Plumber's Putty still works and keeps forever . . .
But it stains everything it touches...
Good to know.
Never experienced that issue myself but I was only applying a thin bead around the back of the driver rim/cabinet mating surface. I guess it has some oils in it . . .
Dirk, I think I'd just use E6000 or Permatex black silicone for that job. I don't normally use the stock ports though and just go for PVC and a roundover.
I have a set of cabs Meniscus built that had those ports installed, and they matched the shape of the backside of those. Recessed, rounded over, and slots for the splines. While I suppose it's a good way to ensure fitment, it's a lot of work for a ~$4 plastic port.
Whenever I install premade ports I apply a bead of clear silicone. Haven't had an issue. It sticks enough to do the job, but not so much it will do damage if you need to remove it for some reason. It's visual impact is minimal if there is any squeezeout.
So, I spent an hour this evening trying to get Google's Bard AI to help me design an open baffle speaker. When I couldn't overcome the tautology of its replies regarding diffraction, I asked it what I should read. It told me to send an email to Sigfried Linkwitz about where to purchase his book. I shit you not.
Google's AI telling you to purchase something...that sure sounds like Google. The fact that it didn't know SL had died and that book is out of print...I don't think AI is ready for primetime yet.
I use chatgpt in the corporate environment for coding assistance, for that it rocks. But when I asked for a subwoofer alignment... It was quite lost.
Apparently, Microsoft is pretty happy with what AI can do. They have a promotional video that they produced with their employees that are visually impaired or blind. The phrase that gets used a lot is "game-changer". It allows them to do things that were just not possible before. Just so happens that my cousin is an employee featured in the video.
We have one app at work for doing spec work that uses AI voice-overs. It has gotten a little better in the past 6 months, but it has many issues with basic pronunciation and inflection that it could never be used for paid work. It's funny to hear how it tries to pronounce Iowa. I'm sure that will change in the next year of so.
I remember watching something where the scientists, using a similar camera, were able to capture light moving through a small chamber. Pretty impressive considering how fast light moves.
If you watch the video you will see that they are doing exactly that. They are also able to see objects that are out of view of the camera based on the ability to capture reflections of the object like sonar.
They are capturing individual pulses of light at different intervals and stringing the photos/video clips together to make a video giving the effect of slow motion light travel in water. Pick it up at 2:30 (mm:ss) and listen to the words spoken . . . it's cool stuff even if the camera isn't as fast as you thought . . .
Looks great Ron!
https://i.imgur.com/I2io6C9.png
https://i.imgur.com/D0p1sLA.png
Radio nerds might recognize the antenna tower in the background... It transmitted at a half million Watts for almost 5 years in the 1930s.
It's happened, guys. I've used the last of my complimentary speaker mounting kits.
Here ya go, Dirk!
https://www.amazon.com/Density-Adhesive-Stripping-Insulation-Long(33ft/dp/B081ZQBQG8?pd_rd_w=A6vuJ&content-id=amzn1.sym.300a3262-566c-4179-a45e-2e093bbf316d&pf_rd_p=300a3262-566c-4179-a45e-2e093bbf316d&pf_rd_r=M6RZ1H9H1JK434VSY2CZ&pd_rd_wg=42rPM&pd_rd_r=ec651657-5107-4d58-ae1c-7e162723c022&pd_rd_i=B081ZQBQG8&psc=1&ref_=pd_bap_m_grid_dv_rp_0_2_i
Nah, man, this was the bituminous rope caulk. Good for sealing press-fit port tubes and not much else. LOL
I know what it was. I remember not being able to get drivers out when it was used too. Pretty sure I threw it away because of the usage difficulty.
I was suggesting a better replacement for the same application.
Good to know.
He's dead, Jim.
As out of print as his book. LOL
A couple things I've noticed from GPS, 11A is 'elevena', Pokagon is 'Poke-uh-gone', and Notestine is 'No-test-in'.
I agree...
Tis the season
Three years after a fire in my shop, and my sound room is finally taking shape. And yes, the fabric is flammable.!
Eggsellent!
MIT has a camera that does a trillion frames per second.
https://youtube.com/watch?v=7Z8EtlBe8Ts
And here I am, hoping to upgrade to a camera that can shoot 120fps 4K video. Seems totally inadequate now.
I often feel inadequate when reading the stuff posted by all you smart guys
