New Products Thread
191011121315»
  • edited May 16
    New Purifi tweeter is now available.
    [Edit: fixed price per wolf's correction below]
    DKK 3,750 = USD 513
    https://ptt.purifi-audio.com/shop/ptt1-3t04-hag-01-ptt1-3t04-hag-01-wg104-2088
  • edited May 16
    Isn't that 3750 DKK? Should be $513.
  • $561.10 USD NUTS!
  • That's RAAAAAAAALLLLLLLL territory.
  • The graphs look very good. I would guess that it's worth the cost, but as with anything the law of diminishing returns is in play.
    Tom_SNicholas_23
  • Negligible Force Factor Modulation (FFM) and Surround Radiation Distortion (SRD)
    WTF kinda BS is that? I mean if it doesn't have Quadraditure Hexagonal Plastisis then what's the point? Oh and no berillllliyum? Tisk tisk.
    rjj45Steve_Lee
  • edited May 17
    @6thplanet said:
    ...Surround Radiation Distortion (SRD)
    I'm pretty sure Sound Radiation Distortion (SRD) only becomes a problem when the surrounds have been stored in close proximity to Uranium-235. But it hardly ever matters - not because it is inaudible but because the listener usually dies from radiation poisoning within hours of listening.
    4thtry6thplanetSteve_LeeImpious
  • edited May 19
    I will not be purchasing those Purifi tweeters, not for any of the reasons mentioned like isotopes or plastises, but because my wife would kill me.
    Ed_PerkinstajanesImpious
  • Wow, same net result, different causes related to the same stigma.
    6thplanetSteve_Lee
  • While I'll be far more likely to go with BZ or Viawave than these, no matter the route the wife would likely have some stern words for me.
  • edited May 17
    @jr@mac said:
    …the wife would likely have some stern words for me.
    There are worse things. I know from experience. 😆
  • Well, at least they stayed with the ugly theme.
    jr@macWolfugly_wooferSteve_LeeEggguyGowa
    Except they seem a lot better. I’ve never heard a rectangle tweeter that I liked - because I want to be able to stand up. The very wide directivity all the way up with a huge and low Fs dome is a compelling combination IMO.
    And I guess they’re still half the price of the replacement tweeters for my Revel Gem2’s- which look on the outside like a Be dome atop a Vifa XT motor with a proper faceplate.
  • edited May 20
    I went to my local show, which is Munich High End. Yea. The listening rooms are an example of how one can fritter away your life fortune on shiny and exotic hi-fi equipment some of which sounds good and much of it not so much. Oh and I listened to that 1 million dollar system from Asia again with the big horns. The horns were not bad but the two subwoofer columns were gawd awful and muddy sounding. It didn't help that they made the entire drop ceiling vibrate and resonate... I almost felt bad for the designer/owner about that part.
    In contrast, the IPS vendor section is interesting and you can meet and greet the manufacturers. I had some great conversations with the Purifi crew and visited the SB Acoustics booth, among others. Which finally brings me to the reason for my post...
    SB will be releasing a new Satori woofer with model number WO34HC-4. It will use the same honeycomb cone construction as the SB42 15" and comes in a nominal size of "13-1/2 inch", making it a tweener between a 12 and a 15. There is no other info, and I only took a pic of the cone with the model number tag inside so it's not really worth posting. Looks very beefy and was indeed no lightweight. I talked to the reps about it and they said the release was slated for late fall, November ish. There is absolutely no information on the driver at this time, no preliminary data, etc. I asked what sort of Xmax the driver might have (it is of course built up and sitting there in front of me at the time) and they rep eyeballed the voice coil and surround and thought 20+mm peak to peak, so it is probably the 12.5mm Xmax type motor system they use on some of the 12" woofers/subwoofers that are related to/derived from/copied from the Peerless XLS/XXLS motor. That has pretty good performance but the 12" drivers IIRC have over 50mm peak-to-peak mechanical limited excursion so maybe not quite the same motor design overall.
    I am keeping my eyes open for any announcement about this driver since it could be an interesting option as a large woofer that isn't quite a true subwoofer.
    kenrhodesani_101Steve_Leejhaider
