1606163656686
  • There are places around here begging for my used oil. They get paid for that shit.
  • Still gotta haul it. That's what makes it a PITA.
  • edited July 2024
    I did my own repairs on my first cars, which were 1956 and 1959 Peugeot 403s (the Columbo model) but got sick of all the mess and oil, etc. I replaced bits like the clutch, radiator, water pump and head gasket but the cars were very simple and everything was accessible. No way would I try anything like that these days.
    I even re-built an engine, but had a bolt left over after job done; luckily for me (but not the garage floor) it was just from the sump pan...
    The most common DIY chore with both cars was the gradual build up of oil in the tubes which held the spark plug leads: the engine was a cross flow head design with the plugs on top of the engine. The plugs had a long spring shaped wire which connected to the leads and distributor through the rocker cover. Unfortunately, when the seals wore, oil would build up in those tubes to the point where it would drown the plug, so I had to carry a bendy straw with which to suck the oil out of the tube!
    Luckily I always managed to stop before oil got too far up the straw.
    Steve_LeeBillet
  • Managed to keep this thing running for 31 years and just let it go 3 years ago to fund another project:
    Rebuilt heads about 6 times, block once, installed cast iron dual exhaust headers and dual carbs, replaced 4:11 rear end with 3:42, replaced original shot manual tranny with 1982 Pontiac Sunbird 4 speed Saginaw manual tranny, replaced front clip with 1974 Chevy Nova to get disk brakes, spindles and rotors installed, redid interior.
    After 31 years it needed more work again than I have energy to put into it - Only had about $35K invested over that time frame so the ownership was quite cost effective.
    tajanesNicholas_234thtryKornbread6thplanetGeoffMillar
    My brother and I had one of those in high school. It was fun, pretty durable and pretty unique in NW Iowa in the late 60's. I assume yours had a crank to start it with?
  • @DrewsBrews said:
    Anyone have much experience with HDPE? I'm making an adapter to attach a router to a router table plate. Using 3/4" thick HDPE. Attaching the plates together with nuts from the underside may not work out due to interferance with the router base. Any idea if threading the plastic is likely to hold up over time?
    I used a piece of 1/4" aluminum. I threaded the aluminum to mount it to the table. If you've never worked with aluminum, it cuts and drills with standard wood tools.
  • edited July 2024
    The router I got has a high power motor that should handle big bits, but a small opening in the base for some reason. I'm planning to use a collet adapter which will give extra shaft length past the base. Then use a thick spacer/adapter to give the bit more room between the base and table plate.
  • edited July 2024
  • Both my 403s had a crank handle, as did the later 404; handy for starting the thing when the battery was failing, or for turning the engine over very slowly (without the ignition on!) for maintenance. Main issue with the crank handle was that it slotted in below the radiator, which meant a high-ish bonnet line.
    While relatively slow, the 403 had far better handling and braking than any mainstream car of its day, and with overdrive was a comfortable cruiser. Great on bad roads, too with 15" wheels and long travel suspension; I took mine on some 4WD tracks.
    And, shock, horror, it had a heater - no Australian cars did at the time. Had a 'start' button too, which carmakers these days consider a big deal.
    The first 403 was killed by rust, the second by my realisation that I needed something more modern and safer in a crash.
    I recall that Phil Hill, 1961 F1 World Champion, advertised it with "between races you can't beat a Peugeot 403".
    jholtz
  • edited July 2024
    Markup
    Hopefully to fit bits up to this big chungus 1.5" radius
  • That's a big one. Danger
  • I would recommend you take the baseplate off your router. Mount the base in a recessed hole at the top so that you do not lose as much depth. DO NOT use a bit extension with a router bit that big. Lexan/Polycarbonate are the best for a clear baseplate if you feel the need (I used to do that I don't anymore). I often buy Lexan "drops" online (ebay) for pretty cheap. Build a fence as well. The fence will help make sure you can control how much cut you are taking in one pass. Having dust collection in the fence and the base will make your life much more enjoyable and possibly longer.
    Be safe. a bit like that will take big bites and pull in anything it can.
    Steve_LeeWolf
  • I have a 1-1/2" bit I refuse to use on my router. Too scary for me. My 1-1/4" bit is just fine.
    Tom_S
  • Yeah, I don't like the sound of collet adapter to give extra length.
  • edited July 2024
    I understand the concern. Any project like this is touch and go. If this specific adapter plate doesn't work out ill figure out another game plan and use this one as a template.
    The table does have a fence and I will definitely use it to take multiple passes working up to full depth of cut.
    Steve_LeeWolf
  • edited July 2024
    That being said, I'll gladly sell my 1-1/2" bit to someone.
  • I recently used my 1-1/2" roundover for a port flare. It does scare me. I used 2-3 passes with my 1/4", 1/2", 3/4", 1", 1-1/4" and finally 1-1/2". By time I got to the 1-1/2" there wasn't much to take off. Of course I could have taken many small passes with the 1-1/2" bit but I don't like having that thing spinning anywhere near me if I can avoid it.
  • Bit sold.
  • edited July 2024
    I've threaded both HDPE and LDPE. Small Fine threads didn't work well but 1/4 -20 was OK.
  • I agree with drew, course threads
  • You mean John.
  • Him too
  • 10-24 was the largest standard button head that would fit in the plate recesses. Failing that i can always go with socket heads in a larger thread or drill out the recesses for larger heads.
  • I used 10-24 in my plexiglass router jig.
  • If you don't need the transparency I would highly suggest G10 phenolic material or aluminum. Check out G10 at McMaster-Carr. They both machine (ie tapped threads) really well.
  • This looks cool: I would hope there's a model F5000 racing car into which this could fit!
    ugly_woofer
  • I'm subscribed to his channel, builds some fantastic stuff.
  • edited August 2024
    Seems like it can work without the extension. 1/2" plate probably would have been about perfect instead of the 3/4". A4e suggest a much better router when I talked to him (thanks again). Though, the hobby budget was running thin after the table saw purchase. Hopefully this gets me by for now.
    Steve_Leejhollander6thplanet
  • That'll do! 👍🏻for no extension needed
  • Day 8, no tobacco. Yay me.
    kenrhodesSteve_LeehifisidetajanesRon_EEd_Perkinsugly_wooferGeoffMillarBillettommytunes50and 5 others.
