15960626465101
  • Oofdah. SoDak record is 66.
    Glad you are safe, brother.
    ugly_woofer
  • Three of those 27 were within 15 miles of me.
  • Did the rest you see Chuck's post on FB about his tree damage?
  • No, I don't have a fb account. Did he get hit hard?
  • It looks like they live out in the woods and had quite a few trees down. One hit a barn and took a big chunk out of a soffit. They are OK, house and cars are OK too, but it sounds like he almost got hit by one.
    That sucks :/ Hoping all is ok with Chuck and his family.
  • Sooo... Long story short, my daughter and her boyfriend had an encounter with a neighbor at their apartment that scared even me, so they now live with us.
    Tonight they are finishing up things there, so I felt like cranking some tunes and having a few beers.
    As my family says, Slainte!
    Steve_Leetajanesugly_wooferkenrhodesPWRRYDTurn2
  • edited July 2024
    Slow progress on my deck roof but progress none the less.
    Steve_Leejr@mactajanes
  • The suction hose fitting on my utility pump broke this morning, so I had to make a replacement. The aluminum piece will most likely out last the pump. :p
    kenrhodes6thplanetSteve_Lee
  • Made a CARtoons collage today for a buddy. I couldn't wait to get a copy of this mag back when I was a kid. Still have some of my old copies. I've had a subscription for the past few years. Great mag for car guys! Any other fans?
    ugly_wooferPWRRYDSteve_Lee
  • As someone who has spent countless hours under hoods and oil pans and differentials and transmissions, I have come to the conclusion my time is way too valuable to perform routine maintenance on my vehicles. My Sorento requires a brake job, and the time was I would set up on a weekend and git 'er done. Nowadays, I might change a serpentine belt. I also air up my own tires, it seems gas stations air is always jacked up when you need it the most.
  • I like working on my cars. I'll do everything but tires and the oil changes, which is just a hassle. I like to hit the time or miles window for the oil changes or I get stresses out. Based on what my last oil changed costs I may want to rethink this.
  • I'm a sucker for Brad Penn/Penn Grade oil and OE or WIX/NAPA gold filters. I have zero trust in oil change places. I will always DIY my oil.
    Billet
  • Same here . I do everything myself except tires. I don't trust any of those 30 minute oil shops to touch my vehicles. I use the Wix/Napa gold filters and Mobile 1 fully synthetic. Brake pads are always the best ceramic I can buy.
    I don't enjoy working on cars as much as I use to but I'm not at the point yet where I'll just pay a shop for sonething that I can totally DIY. And sometimes do a better job because it's my family relying on that car/van and I'm not getting paid by how many jobs I can complete in a day.
    I still mow my own yard too. Only takes me one hour and I need the exercise (push mower).
  • edited July 2024
    I work on my own cars, mostly because I want to know that maintenance and repairs are done correctly. And if there are issues, at least I know exactly what they are.
    6thplanetjholtz
  • I would change my own oil, but Subaru has a free 150pt inspection with every change. I don't like doing brakes, but have. I could do plugs and wires if access was easy, but apparently that gets sketchy in aluminum threads. I pump up my own tires. More than that and a hand wash, I don't do much of.
  • @tajanes said:
    Rat Fink
    tajanes
  • edited July 2024
    After watching my family get bent over every time they had work done on vehicles. I begrudgingly do all my own auto repairs. I'm not paying out the nose for someone else to do a worse job than I can with basic hand tools out in the heat or cold.
    PWRRYDBillet6thplanet
  • edited July 2024
    Anyone have much experience with HDPE? I'm making an adapter to attach a router to a router table plate. Using 3/4" thick HDPE. Attaching the plates together with nuts from the underside may not work out due to interferance with the router base. Any idea if threading the plastic is likely to hold up over time?
    Yep. A girl friend I had about 20 years ago swore by a certain shop that she and her whole family used for everything. The shop owner was supposedly "a family friend". I saw his shop's work and the invoices... $1800 for a clutch change on one of the easiest cars in the world to work on? I found a high quality new clutch, pressure plate, and throw out bearing for that car for $250ish.
    I get it though. If you don't own the proper tools, you don't have the proper skills, or you live in an apartment where you don't have the space to do the job then there isn't much else you can do.
  • @PWRRYD said:
    Rat Fink
    Geeze - should have kept some of my old models from when I was a kid
    6thplanetTurn2
  • Getting rid of oil is a pain.
    I've been using the group of guys for tires and other misc vehicle maintenance for 35 years. Grew up with one of the owners. I'm ok, but sorry for people who have yet to find a mechanic they don't believe isn't ripping somebody off.
    Wolf6thplanet
  • Other things like fan motors, wipers, lights, thermostats, gear shift pulleys, etc; little stuff; I've done quite a bit of. It's the clutch, transmission, timing chain, diff, drivetrain, etc that I have no business doing for lack of instruction, space, tools, or time. I'm definitely not touching the AC.
    Yes, oil is hard to get rid of.
  • edited July 2024
    @tajanes said:
    @PWRRYD said:
    Rat Fink
    My old man has an extensive collection of still in the plastic Revell, Monogram, AMT, and Ertl model kits. Some of which are fairly valuable.
    Steve_Leetajanes6thplanet
  • I used to build a lot of scale model rockets and aircraft in the 60's while sniffing a lot of glue.
    Kept me out of trouble.
    tajanes6thplanetEd_Perkins
  • I do everything on my cars, doesn't matter, engine trans, rear end, whatever, it's just parts bolted together. I actually had 2 of my vehicles have the A/C compressors fail last year and the Hyundai one was expensive. If I remember correctly I paid about $600 for the compressor and it didn't even come with oil.
  • I pump my own gas. That's about it. I'm not sure where the lever is to pop my hood but I'm sure I can find it in an emergency.
    Ed_Perkins
  • I had a 1983 Toyota Starlet for years and years. It had 324,000+ miles on it when I pulled into the Nissan dealer and traded it off for my current Nissan Versa (2010). Engine still ran good, did not burn oil, but the car body was totally rusted out along the wheel wells and was in real danger of structural collapse.
    Changed oil/filter once per year. Pulled the transmission out myself two or three times, replaced input shaft, front main bearing, and seal. Replaced clutch, throw out bearing, and pressure plate once. Replaced alternator two or three times. Replaced thermostat several times. Replaced drive shaft U-joints two or three times (this was rear wheel drive). Replaced front and rear brake pads several times, replaced front rotors once. Replaced entire exhaust system several times. Car was alot of work to keep on the road, but very dependable, one of the best cars I have ever had. Got 44mpg on the highway. Very small car, easy to park and see out the huge rear window when backing up (unlike cars today, which have very small rear windows and therefore need rear cameras to see what is behind you).
    BilletKornbread
