14142444647101
  • Looked up the specs. That is quite the machine! Even cheaper than the Stanley Miter Saw!
    Looks like Man U El labor to me ...
  • Bet the saw blade is dull after cutting against that cast iron without a sacrificial base board . . .
  • Most of those saws had stops that would stop the teeth from hitting the metal.
  • edited February 2024
    @Tom_S said:
    I'm not quite sure what that power supply is actually for. Google says it's for electrophoresis, whatever that is. My old college roommate works in a hospital lab & would probably know.
    While DNA electrophoresis would be done in a lab setting, that looks like what you might use for metal coating in an ion bath. Just a hunch on my part.
  • Metal plating uses very low voltage and high current (depending on the surface area of the parts). That "Warning High Voltage" leads me to believe it is for something else.
    6thplanetTurn2
  • We had a Renault 16TS which was "Electrophoresis Protected" from rust; the process used a bath of stuff and an electric current to supposedly make the rust treatment stick to the internal metal.
    However, some berk at Renault got either the chemistry or voltage wrong and instead of attracting the treatment, it repelled it so that the car was a rust bucket within two years. Pity, as it was comfortable, fun to drive, practical and a great car: first one in which I I did 100mph.
    French designer obsolescence
    Too bad - good idea
  • Renault sold cars in the US in the early 1980's called Le Car. They were very well known to have huge rust holes in the doors and quarter panels after only 2 or 3 years. I had a friend who purchased a used Renault that was 3 years old and had less than 40,000 miles. It was the biggest piece of junk I've ever seen.
    I remember my father purchased an early on Honda Accord. In it’s 2nd year the dealer called him in and replaced both front fenders - he was told Honda found an issue that could lead to rust -
  • Slammed my twin brother's hand in a LeCar door. He screamed, I didn't feel a thing.
    tajanesugly_woofer6thplanetSteve_Lee
  • Was the the Le Car the one you had pull the engine to replace the starter? A friend had one and told us something like that. Luckily he worked as a detailer at the dealership and payed one of the mechanics a hundred bucks to do it after hours.
  • Red sky this am
    Eggguyugly_wooferSilver1omojr@macDrewsBrewsPWRRYDSteve_Lee4thtryTurn2
  • I need a bigger pic of that for my PC background!
    tajanes
    Busy weekend sofar.
    After the growing season of '22 I fermented my last big harvest of peppers. Banana, Anaheim, and Cayenne. Added some chopped carrot, onion, and garlic for flavor complexity. Yesterday, after sitting over a year fermented in the brine, I finally decided to make it into hot sauce. I added a couple Tbsp of Kamebishi 3year traditionally fermented soy sauce too. OMG I could have just bottled the brine and been happy. But this stuff is interesting. In the tabasco vein but definately different.
    Today I decided to finally bottle the beer I brewed with wild hops I picked a few months ago. A few bottles I added a couple chunks of toasted oak to see what that would do.
    Silver1omoPWRRYDkenrhodestajanesSteve_Lee
    That was the Renault 5, but unfortunately, that's an issue with many modern cars too: Mini, Volkswagen Toureg and certain Jaguar and BMW models come to mind.
    Other idiot design features include timing chains at the back of engines - so you have to take the engine out to change it - cooling alternators with fluid, oil coolers inside radiators, fuel pumps inside fuel tanks, etc etc ad nauseum.
    Some cars are like that by the nature of their design - as in Subarus, where you have to remove the engine to change the head gaskets as it's a flat four - some are just plain stupid, where the engineers haven't bothered to consider the problems when some poor person has to replace/repair part X.
    As one Australian YouTube mechanic recently put it: if you buy one of these (insert make here), your mechanic can put their children through the very best private schools!
    Harvest and toast your own oak?
    I suppose it wouldn't be that difficult to run some 1/2" boards through the saw to get little chunks and toast in the toaster oven.
    But no, I used some pre-toasted cubes. Threw it on an order for $5 on a whim.
    My 2010 Nissan Versa currently has 90k miles. At 120k, I need to replace the spark plugs. When I bought the car, the saleman really bragged about how these newer engines run very clean and require fewer oil changes and spark plug replacements. But now I found out that I have to spend 2 to 3 hours tearing off all kinds of hoses, connectors, gaskets, etc., just so that I can reach the spark plug coils and spark plugs. Not looking forward to it.
  • Just did the spark plugs on my Toyota 4 cylinder. Maybe 30 minutes.
    My garage almost breathes a sigh of relief when I bring our 2002 Mazda MX-5 (Miata) in for service - normal maintenance items are easily reachable, rear wheel drive, not too many electronic things. It does have a few idiot design features such as the fuel pump being inside the tank.
    The chief technician at 'my 'garage - I've been going there for 44 years - is a computer scientist and his expertise is invaluable with all the stuff that's on modern cars.
    Our main car is a Mazda CX-30: lovely car, but the manual is 600 pages long and I still can't understand much of it.
  • I know it's a different engine than yours Bill but I can change plugs in my Nissan Altima in less than 20 minutes. Changing the oil and filter is a different story... without a lift or pit I have to jack the car up and remove the passenger side wheel and a plastic cover piece. Then the oil runs straight down on the frame rail. Completely stupid design for sure.
  • Here is a video showing how to replace spark plugs on a 2006 to 2012 Nissan Versa. This is identical to my car. Maybe an experienced mechanic could knock this out in 30 minutes, but I certainly could not. I'm thinking 2 hours minimum, probably 3 hours or more.
    Tom_S
  • Greetings from Paris.
    Paris, Texas that is...
    jr@mackenrhodesugly_wooferSteve_Leetajanes6thplanetTom_SPWRRYD
    Damn that's a tiny car. Usually transverse 4 cylinders are easy, with the plugs right up front.
    Don't know if people have seen this, a great show with legendary names: Clapton, Jeff Beck, Steve Winwood, Jimmy Page, two Stones, Ray Cooper, Simon Phillips and an encore from Ronnie Lane, for whom this was a benefit gig. Not great quality footage, I think it's from a VHS tape, but sounds acceptable.
    There is a semi-legal double CD set of the show with better sound available from various sources, if you look around enough.
    With the addition of Joe Cocker and others the entourage visited New York, but Jimmy Page was not well and the shows weren't very well filmed or recorded.
    Spark plugs, yup, I feel your pain. Have to remove upper intake plenum on the G35 to access the coil pack/spark plugs. 🤦🏻‍♂️
    The Saturn is exact opposite, standard 4cyl, right on top, easy peasy.
    I loved my 5speed vue (2.2l ecotec). Probably the cleanest factory engine bay I've seen that made for super easy work. No trans fluid lines because 5speed. Electric steering and throttle so no pump/hoses/cables. Most of the emissions stuff was either unnecessary so omitted or direct mount on the engine. No vvt or any of that advanced stuff that has expensive actuators that die often. The oil filter is accessed from the top, points upward, and uses a large socket to unscrew (super easy and no oil covered hand). Unfortunately the water pump is chain driven (can't win em all) but that is typically a one and done headache unless you are realy squeezing the miles out of it. I'm going to have to give myself a kick in the pants and swap that engine out this spring.
    So I have an engine with ~200mi on it but it has been sitting for near 2 decades (only paid $300 with an attached auto trans). The seller told me he got it from a speed shop in Tennessee that pulled it from an 05 cobalt to swap for a factory race engine. He planned to drop this stock 2.2l in a rail or something but sat in a storage unit instead. I did some research and the story lines up with the release of the chevy phase 5 line of drag race prep parts. The center piece being a 500hp turbo 2.2l with a beefed up auto trans. Kind of neat. I'd believe this barely has any miles on it. None of the typical aluminum corrosion, only a light patina coating from sitting. Last time I turned it over by the crank I sprayed some oil in the cylinders and it was butter smooth so hopefully still OK.
    Anything I should look into replacing on it while it is out of the engine bay? Someone suggested the timing chain guides due to age that plastic tends to fall apart. I thought maybe the water pump too as who knows what that amount of time has done to the shaft that might wreck the seal immediately. Openings were taped over except the fuel rail. Plan to pull the rail and blow out the inevitable dead bugs. Hoping vaseline might keep the injector orings from scoring in the process.
  • There's always risks with things sitting that long, especially the cylinders. As for seals, replacement parts sit on shelves for who knows how long till someone buys them. Plastic parts, the guides maybe worth doing since it's out already and like you said, the water pump is right there.
    I don't have any experience with the EcoTec, that's a GM engine. My stuff is actual Saturn.
  • Takes just about 10 minutes to change plugs in the old Truck. The headers make it a little bit of a bitch, though.
    Worst I had ever done was the wife's Grand Prix (early 90s vintage) with the 3.1L V6. Had to take loose the dogbone motor mount and rotate the engine forward and hope to whatever deity of your choice that the plugs came cleanly out of the aluminum head.
