Gosh that would be perfect if it just came with a remote. I know it isn't so much an issue in bluetooth mode.
Looking for something affordable I could refer friends to that wouldn't burden them with "quirks".
@DrewsBrews said:
Ooh even has a high pass filter.
One shortcoming of DIY is the amplification side of things. This is close to perfect, but yes a remote would be nice to have.
Now they have one less. Thanks for the heads up. I'll see what's up and why they may have been returned, my guess is they did not measure as advertised.
I'm a sucker for this kind of item so I ordered a pair. Will let you know what I think after I get them and do some measurements and listening. Anxiously waiting to see that "SOPHISTICATED CROSSOVER NETWORK".
Reminder that Meniscus' last days are here, with the lease running out Monday.
Discounts increased tonight - 70% off on sandcast resistors and CEBO capacitors. 40% on everything else.
A lot of drivers are gone, and some remaining are just singles, but there are still some good deals to be had. Also, lots of inductors, high-end and large value capacitors, ports, wire connectors, spikes-feet, etc.
@6thplanet said:
Is the price showing at Meniscus before or after the discount?
The correct price is calculated when you go to the cart. However, when adding things to the cart, the little cart icon in the top right corner shows a running total that does NOT reflect the discount, you have to actually go to the cart to see the correct total.
The thing is a tank, have not measured it yet. Hope it is close to advertised - will make a killer sealed sub if so. I have a spare Dayton 250W plate amp that would be about perfect. If it does have cocked up specs I'll buy the Dayton 500W DSP plate amp and fix it.
As of the time of this posting you can pick up the HiVi 3" dome for less than $80 off AliExpress:
https://www.aliexpress.us/item/3256804539155439.html?spm=a2g0o.productlist.main.13.11613756xcrAeM&algo_pvid=5e261dcc-7331-4d10-8b0c-be1813a31e7e&algo_exp_id=5e261dcc-7331-4d10-8b0c-be1813a31e7e-6&pdp_npi=3@dis!USD!84.46!79.39!!!602.00!!@21224cdb16895953216493850d0765!12000030241908101!sea!US!132555799&curPageLogUid=lfI40zCP5xRm
I’m seeing the Beast Mode DX25 on sale at Madi for $30!
https://www.madisoundspeakerstore.com/soft-dome-tweeters-vifa/peerless-dx25bg60-04-1-textile-dome-tweeter-w/double-magnet/
Good deal on a great tweeter, especially with a lot of peerless drivers going MOQ or NLA
Vifa/Scanspeak P17WJ-00-8 new in bulk volume $50/ea . . .
https://www.ebay.com/itm/165818902184?chn=ps&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=165818902184&targetid=4581183931512196&device=c&mktype=&googleloc=&poi=&campaignid=603247656&mkgroupid=1241349622402367&rlsatarget=pla-4581183931512196&abcId=9316139&merchantid=51291
Specs/FR:
https://www.falconacoustics.co.uk/downloads/Vifa/p17wj-00-08e.pdf
At $50, this woofer still holds up IMO.
All Electronics is closing by end of August. Some good deals to be had for sure...
https://www.allelectronics.com/
Hi-Vi L6-8R 6" Woven Cone Woofer on sale at Madisound for $36.
https://www.madisoundspeakerstore.com/approx-6-7-woofers-hivi/hi-vi-l6-8r-6-woven-cone-woofer-with-phase-plug-8-ohm/
Of course it's the 8ohm, I need the 4ohm
Just buy 4.
If only crossovers worked like that.
PE has 3 GRS 15SSW-4HE restocked @ $48 each when you use CLEAR723
No idea what I'll use it for, maybe as a ULF in the living room.
Or buy an old shit box, 500W amp and throw it in the trunk.
Looks like someone grabbed the remaining two.
Peerless 830667 come out to $33 a piece.
How about monoprice encore t5 tower for $89 and free shipping?
https://www.monoprice.com/product?p_id=43152
Those look pretty decent for that kinda cash.
That's what I was thinking. 35lbs for a 6 x 10 x 36" tower seems like the cabinet might be ok too.
The Monolith line is pretty legit for affordable commercial audio
https://www.madisoundspeakerstore.com/deal_of_the_day
That's a tiny looking can...
It arrived!
