1…1415171920…98
  • I remember an 8" Full range Tangband driver which is an older model.
  • PWRRYD said:
    JR, didn't we listen to that Tang Band in Chicago at Axpona?  It was in those large OB WFW with an Alpha 15 above and below.  That's where Bryan sat on the floor to get the TB at ear level.
    That was the 8" with neo array motor. BK had the right idea, glad I joined him.
    Ed_Perkins
  • Another light.
    jr@macTurn2
  • What's the price?
  • $499 ... well $hit, they're $19 cheaper on Amazon.  Odd, I though massdrop generally had good pricing on their stuff.  Anyhow, always wanted a Stax combo back in the day wonder how these would compare?
    Time to get back to work digging out a stump before it rains.
  • Drop does a lot of custom work to the products. Different tunings colors ect. Not a bad price if you value the custom options.
  • They've been having a lot of 'affordable' planar headphones lately.
  • 6thplanet
    I see them at $450 in Drop.
  • edited May 2020
    " ... good choices for 2-way speaker systems or even as midrange in 3-way systems" ?
  • They mangled the description - based on that drivers advertised response above 1K I wouldn't use it in a 2-way, and based on its ability to play pretty low I wouldn't use it as a midrange. That looks like copypasta from other drivers lol.
    Seriously, the off-axis shows a less than well designed cone indicating it is silly to consider it for 2-way use. Given that, the addition of the shorting ring and copper cap isn't as much a value added feature. I wouldn't personally cross higher than 500Hz on it. It really calls into question the value of it, especially at normal prices.
    The $40 MCM 8" models just as well, has similar build quality including a copper cap, more Xmax, and many of them have been measured in the wild and they exhibit excellent consistency. They are just over $100/quad when on sale and even at regular prices it is a fantastic value for a cast frame, long throw, low distortion driver.
    dcibel
  • Need my butt kicked for not buying the mcm's when they were on sale.
  • I didn't either, but that's ok.... i came to the conclusion that buying at full price when required is better than buying at sale price and hoarding for a project that may or may not happen and paying for storage....
    that doesn't mean that i have stopped hoarding or buying.... but i would like to
    kenrhodesjholtzrjj45
  • I'm not sure if I'll use the MCM or not, but shipping them will be costly so also not sure I'll sell them. Hmm...
    ThumperTom
  • The Wavecor 8" can be used in a 2-way. Balanced drive motor is a huge value added feature, it's more than just a simple copper cap.
  • If you are talking about the 55-5670, they are on sale for 39.99
    https://www.newark.com/mcm-audio-select/55-5670/8-die-cast-woofer-8-ohm-rubbber/dp/95Y2936
    At one time they were on sale for, IIRC, $27.  I loaded up the cart and balked at shipping.  Keep thinking they will have another sale on them but I guess this ain't PE.
    I agree.  I have a pair of these at home right now that I plan on using in a 2-way, probably with some Scan 9900s.  Can't decide if I want to go sealed stand mount or ported floorstander.
    dcibel
  • @DanP I always knew the ScanSpeak 9900 was one of the best, but you really see why when someone dismantles it.
    DanP
  • what am i looking at? Don't know much about driver internals to judge what is what. Anybody mind stepping through the good bits?
  • Also to add to it, anything to look for on the T/S specs, FR / Distortion / waterfall charts to determine exceptional drivers or to value pricey ones as to what makes them good.
    JR mentioned something about the FR impedance relationship in the dayton WG tweeter - that looks similar to the SB WG tweeter that might indicate some issues in XO or sound signature, etc...
  • What I see is an interesting scalloped front plate chamber that I've not seen on other tweeters.  The pole vent hole is quite large with respect to the pole piece.  The poll piece stuffing looks like well shaped and trimmed wool felt.  The glue dabs could indicate some type of filler piece in the pole vent.
    I've wanted a pair after hearing these in the Spirit Winds.
    ani_101
  • The following is a paid advertisement for Scan Speak :)
    The obvious bits are staples of a good linear motor. Extended pole piece and full copper sleeve.
    In the pole piece you don't have a simple round hole but a more complex shape to break up any reflection that does make its way back to the diaphragm. On the outside is the area that goes neglected in many tweeters, the airspace behind the surround. Again, lots of airspace here and a complex shape to mitigate those single frequency resonant modes. All together you are trying to remove any back pressure / compression effects that create distortion. The 9900 also includes a nice big cast face plate with a mild waveguide that helps to reduce cabinet diffraction effects.
    T/S parameters are pointless in a tweeter, however something can be learned from the impedance. Remember that a speaker is a transducer, and that means that it converts one type of energy to another, and it's a 2-way street. Not only does a speaker convert electrical energy to acoustic, but acoustic energy to electrical. All speakers are microphones, just poor ones for the most part. The microphonic effects are visualized in an impedance sweep.
    Little blips and wiggles are indications of reflections or resonances. If you can take your own impedance measurement, try doing a sweep with and without your hand or a board in front of a tweeter. The higher sensitivity the driver, the more pronounced these impedance issues will be. If simple putting your hand in front of the driver has an effect, it should be clear that loading a driver in a horn or waveguide has a significant impact on the resulting impedance.
    Low Q humps in the impedance sweep are indication of inadequate chamber stuffing or airspace. They are usually accompanied by a dip in the frequency response. Depending on the crossover frequency this may not be a huge problem and may work to your advantage for a passive crossover, however I would not expect to see such "issues" in top of the line products. A good example of this being more of an issue is the Dayton RST28, as you can see a clear bump at 2.2kHz and a dip in the frequency response as a result.
    An example where this is less of an issue is the Scan D2608 (aka Peerless HDS 810921 ). In this driver the hump is less pronounced around 1.5kHz, and creates a low Q response. This is easy to work with a 1.8-2kHz crossover frequency and actually aids to avoid a bump in the rolloff due to the driver Fs.
    When it comes to dips in tweeter response, also consider a typical baffle diffraction response, here's a 9" wide baffle.
    As you can see, generally there is a bump at 1-1.5kHz followed by a dip around 2.3kHz. In the case of the RST28, this exacerbates the dip that already exists in the response, so the problem becomes worse when you install the tweeter on a baffle. The low Q response of the D2608 is much less of an issue here.
    ani_101
  • wow, thanks john and Decibel. I'll have to take some time and re-read it. Most just went over my head. Any other opinion or observation, please add in.
    Also, is there something to glean from the T/S or FR/impedance sweep for woofers, other tan the obvious box modelling, low end extension, break up points? Like, if i am looking for a dedicated mid, is there something in the TS / FR / Impedance I can look out for? similarly for dedicated low end duty under say 300hz or subwoofer duty. anything to indicate a good overall woofer that goes low enough but can also be crossed higher. I assume all these have some trade off or the other that makes them good for a certain application, but best to be avoided for others.
    PS, John, I have always like the spirit winds since i heard it - one of my favorite speakers.
  • I liked the Raal too.  I need to develop my industry contacts to see if can get some reasonable pricing...
    While I find the specifications interesting, there's no predicting if the sound is worth the $ by specs alone.
  • Agreed, the sound doesn't always follow the specs, but at least the specs can give an early filter / indication of what it might be good at - the reality can be quite different (even in the specs and what the specs translate into sound).
    What i want to try is the RAAL 70-20, but there doesn't seem to be any source for it... anyways i am not ready for a project with it, so it's sitting in my wishlist....
  • Usually the larger mids or woofers will have a small peak at about 1-2k in the impedance for the 5-7" driver, and lower to about 800-900 Hz in an 8" woofer, corresponding also to a dip or peak (depending) in the frequency response. These are surround resonance artifacts. Even the Satori 7" has a dip at 1.5k with the blip in the impedance.
    The F6 blemish is lower at about 900/1k due to the larger frame. I notched out the peak and improved it immensely.
    I had this in the Morel CAW634, and I found it lacking in that range for clarity. Some will say it's not audible, but I feel you can 'miss' something if you don't know what is not there. When I swapped in for the TSCW636 (which supposedly has a mild peak there at the same point) the lacking or loss was no longer a problem.
    Anything such as these should be seen as energy storage, even if measuring a dip in FR. In a waterfall, that dip can form a ridge in the decay.
    ani_101
  • Oh- that is not my measurement. It came from another person explaining this issue to me.
    This is one of the best 2 or 3 tweeters I've ever heard.  Worth every penny IMO.  I got a little nervous a while back that they would be discontinued and I bought a pair, but I haven't used them yet.  The guys at Scan said the motor on the 9900 is the same as the 9700.  The only difference is the mild WG faceplate, but it seems to make a pretty big difference in the sound quality.
    dcibel
