GRT 145 Second Gen Viawave tweeter is getting tested and finalaized.
1246
  • edited March 2018
    We've come a long way from a table saw, router, and drill press.
    The end results from CNC are just too good.
  • I can't help but think of a Monty Python skit:
  • Not trying to thread jack or derail thread but i recently cut a baffle for ld22 but havent progressed to measurements yet. I do like the faceplate idea.
    dcibel4thtryNicholas_23
  • I think I want new wooden faceplates for all my tweeters  :)
  • I like the wooden guides myself. :)
    If anyone wants to send me 3d file, I can take a stab at it next time, I am machining guides.
  • It was my first 3d cut ive made my on machine. I didnt want to risk messing up real wood baffles and still need to verify it works as design before i invest further.
  • nice, how we do order the guides?
  • I am trying to see what species and how many guides I can get an order for. Also, if there's a preference between finished or unfinished. They do take a bit of time to CNC so I am not sure on the price yet. What do you guys think?
    greywarden4thtry
  • Kaiser Acoustics in Muchen.
  • GRT-145-4 now has an 8ohm brother. I should be getting a few pairs of GRT-145-in 2 to 3 weeks.
    Silver1omoS7910
  • Hey guys.
    Opinions needed.
    Dmitry has been asking me to come up with a kit or just a design for DIY crowd. Obviously, public design sells drivers etc.
    I stated working on the small monitor, using 8ohm GRT and 8ohm version of Vifa NE 149 (which is really excellent driver. Surprised it's not used in every other build.) Initially, I looked at PE cabinets as a target for front baffle size to make the design easier for DIY crowd with limited amount of tooling and desire to build complete cabinet. It looks to me tho that the pricing on PE boxes went up and they are much less attractive now VS a few years ago. Are they they still the bee's knees ?
    The other option is to come up with the complete pre-cut kit. If that's the case, what would make it attractive?
    Thanks for the ideas in advance!
    kennyk
  • I don't built kits, but the biggest selling feature to me would be items that can't be easily made at home by running some boards through the table saw, like the nice cut wooden waveguides.
  • I think it would be a great kit, especially if it's small enough for a desktop. Something like faceted baffles or integrated slot port might lure people who normally wouldn't buy a full kit. Maybe offer a few tested & documented voicing options - flat, more BSC for free-standing position, a BBC dip, or gently sloped treble response for nearfield listening. Make it an experimenters package! That ended up being a good business model for Doc at Bottlehead years ago.
    Just to add to my own speaker design toolbox - How would you tackle the abrupt step down in the NE149 response at 1.5K?
  • edited October 2018
    Isn't that woofer used in  Curt Campbell's Microstatements?
    http://speakerdesignworks.com/MicroStatements_2.html
    Hi Tom,
    I'm not sure how the factory measurements compare to the actual but this is a nearfield measurement Curt took of the NE149 we used in the Finalists. It's a very nice sounding driver, IMHO! You can check the Finalist crossover on Curt's website to get an idea of how he approached taming the driver.
    HTH
    Jim
    Gowa
  • jholtz said:
    Hi Tom,
    HTH
    Jim
    That does look better than the graph on their spec sheet, even if the resolution isn't the same. Things must smooth out a little on a narrower baffle. I'll have to check out Curt's writeup again.
    Thanks!
  • Will these be available as a separate item? I'm ready to feel the love.
  • My data on Vifa NE is rather similar to Curt's.
    Which items?
    So, may be include front baffle in a nice veneer with cutouts done? This way, only the box needs to be added.
    dcibelNicholas_23
    Which items?
    GRT-145-
    BTW, I recently measured a bunch of 4-5 inch midranges, and the Vifa NE 123 came out great.
    Hi Roman,
    I'll throw in my $0.02 worth. :-)  The front baffle CNC'ed with a CAD drawing included showing the speaker with a cut list and even a first time builder could build it.
    It should be a very nice speaker!
    Jim
    Which items?
    GRT-145-
    They are available now. The 8-ohm version is new and I only have 2 pairs left (I'd like to keep one pair for myself for the design) but the next order will be placed soon.
    I've used 123NE before. Liked it a lot too.
  • jholtz said:
    Hi Roman,
    Jim
    Hi Jim.
    Yeah, I agree. DIYer with a table-saw and a few clamps may not necessarily want or able to do a veneered panel with accurate cutouts. So, perhaps I will include it in the kit.
    It's an easy speaker to design. Both drivers overlap quite a bit and both have low distortions.
    Even Home Depot will cut wood. It's the baffles that are the toughest. Also, don't forget Leland over at SpeakerHardware.com
    Baffles and veneer are actually quite easy for me. I own a small woodworking shop and one of the tools is a DIY 4x8 CNC router.
    So, yeah, I think, I'll go with nice veneered baffles, included in the kit.
    Thanks guys!
  • Hey guys.
    Opinions needed.
    How do you compare the ne149 to other higher end drivers like the satori and revelator offerings? It looks nice for sure. I've never measured the set i have. I am going to need to liquidate alot of my speaker stash here soon. Quite a few new unused drivers with the ne149-8 being one pair.
