There seems to be some interest in this so I figured I would post it up. I've had some drivers and veneer on the back burner for a few years and decided to do something with them. I got them all measured and Craig got me squared away with the files and a base x-over to start from. I don't have exact values on hand for this but ordered a bunch to test this week. It's going to be close to see if I can get something I really like built in time. I'll bring them to indiy either way but it may not be a final product. They are completely finished and nice looking from that aspect.
The first option sounded pretty good there is a little off-ness in the lower mids i need to figure it. The below info is an option I want to try. I wanted to give the woofer a little less slope and take a touch off the tweeter db wise. The phase still looks really good. IT's going to be a balancing act with really sharp roll offs on both drivers so you dont hear an abrupt transition. I really really love the sound of the tweeter in this guide. Im listening to demos and hear alot of cool stuff. The woofer RS270P-4 is as little quirky, I may need to change to a 3" port from a 2" port or just seal it for the time being.
As always question, comment, critique as you see fit. I don't offend easily.
First picture is the raw measurements and measurements with the filter in place.
Summed response with rev null
Summed response
Tweeter circuit (not targeting 2 order just didn't change it)
Woofer circuit (not targeting 2 order just didn't change it)
So I see you mentioned the RS270P-4, but what is the tweeter. I'll hazard a guess: RS28A in the SEOS guide?
The drum tracks sound really good. I dont feel a ton of air coming out of the port or any chuffing yet or maybe i just used to aluminum cone drivers. This is by far the most challenging design i've had to work with. Its doubtful ill have a "final" version by this weekend. I will probably need to play with crossover points a little more.
