Last Sunday I made the 3+ hr. trip to Roman’s (R_Carpenter) shop to take delivery of what will ultimately be my hobby-killers. Sure, I will design and build. I mean once the virus is in the blood stream, it never leaves…It just goes dormant. However this design that for me is the equivalent of an “all-in” attempt at my definition of as close to a perfect loudspeaker as one can get (we know there is no one perfect loudspeaker) has taken on more meaning than I could ever imagine.
Months in development, these cabinets made from 1.5” ranger board with 13 layer BB ply bracing are a combination of modern CNC milling and decades of hand-made knowledge to assure the final shape, size, scope, and even the 3 degree angle on the front baffle was executed flawlessly. The mitered corners with compound angles were a challenge in of themselves, let alone the thick material and large, heavy panels.
The bottom line is I could never make these cabinets myself, though they are at least 50% of my design requirement. As the build progressed it occurred to me that the hours of work both mental and manual that Roman put it truly makes what will be the end product as much his as it is mine.
Their name, “The Diomede”, is homage to two small islands that sit directly in the middle of the Bering Strait. They straddle Russia and the US, the international time zone, and bridge two worlds together by only a matter of a few miles. Roman and I both have Russian heritage (him far more than I), and both of us are proud to be in the USA where we are able to make a beautiful work of art mashed with technical rigor come to life.
So a huge thanks to Roman for taking on such a challenge and as always doing a flawless job. Now it’s my turn and I can only hope I can make them sound as good as they are built AND look! Or, not ruin the look when I apply a finish....
Impressive design! And massive. How much do they weigh?
Also, a little bit of this could be just an optical illusion, as Roman is standing about 2 feet further into the background.
Makes for a cool picture
Its a mix of both. Roman is average height, I am 6'3", and John nailed it, he is a couple of feet back. It is a cool illusion.
Driver line up is
Reminds me of this shot from Iowa....
I am wondering about the BSC. Where and how are you planning to cross?
Seas L26RFX/P is 88 db
Morel TSCM634 is 89 db
I am assuming full BSC for the seas woofer, but is the baffle going to be wide enough that the Morel mid woofer will not need BSC?
The peak of the BS will be lower, but not gone. The double woofers make for +6dB sensitivity over nominal, and then yield 94dB net. He'll have 5dB of BSC capability from the get go.
I even had BS to deal with peak-wise in the Cecropia, and that's almost 16" wide.
Or is the morel woofer crossing high at 800+ hz?
