My ugly InDIYana 2024 theme project
1235»
  • Thanks, I need to finish a couple that need paint, and this winter I plan on starting a CBT.
  • So, after living with these for awhile… your thoughts on the ESS Heils?
    I see that Pure Audio Project crosses these over to a pair of 10s, stating first order series 700 Hz, which seems to be a bit of a stretch- but apparently not? If so, that’s impressive. I’ve leaned towards trying to keep crossovers out of the 1-4ish kHz area, and finding (excluding coaxial designs) the higher Xover makes integration of mid to tw difficult. Maybe I should be looking at going under.
    Where would you draw the line, is a first order (maybe 800Hz) possible, or better 3rd order hp?
  • edited July 26
    800hz is the point where the distortion just starts to rise, so if you crossed it there 2nd order all should be well.
    It's a very clean driver. I like it a lot, in fact I was going to buy another pair a few months ago, but at the time the shipping was $75 which irritated me so I didn't go through with the order.
  • Thx, I'm sold.
    Easy enough to swap in and out with my latest build (1.5 way sealed bass, top box interchangeable) and size-wise, relative to my AudioNirvana box, will still tuck in behind the front grill.
