I know... not the greatest name for a DIY speaker project but I really suck at coming up with cool names for my projects. Muskie is a somewhat meaningful name though as the drivers for this 3 way are like that fish, hard to find. The paper 10" woofer, RS270P-4, is now NLA. The 6.5" midrange, PM180-8, is now NLA. The 1" corundum dome tweeter, DA25TX, is somewhat avaiable I think. Anyway it will be a big bass bin with a top MT cab. Lot's of pictures to come.
"The speaker of a thousand cuts," I like your name and can't wait to see the progress. Way better than "Esox"....
I really like that RS270P-4. It has better low end than the RS225 in a TL. I didn't make a huge enclosure either, You going to front mount or side mount it? I bought an extra some years ago in case one of mine failed. My enclosure was 12-7/8" Wide X 12-3/8" Deep X 18-5/8 Tall. That width allows for a 1" round over nearly touching the woofer (maybe 1/8" flat to the basket). All 3/4" material however the baffle is 1.25 or 1.5" thick. I can remember. I went with a 2" port ~ 6-3/8" long. A 3 inch would allow for more SPL without farting / port noises but wouldn't fit. I thought I remembered it was in the 102-108 range was when the 2" made noises so I figured I'm probably not listening much at that level LOL.
I posted this in Nick's thread. These are the MT boxes:
Having pursued the elusive fish I can get behind the name!
Look forward to seeing this build.
Those PM180 drivers are supposed to have very good sound quality - there was some use of them some years ago modified by slit cone technique. I've got a quad on the shelf now for a future project.
I do plan on modifying my pair. Seriously hope I don't screw them up. Baffle rebates and through holes completed
You have a much greater tolerance to heat than I do. It's way too hot & humid for me to be doing much of anything outside today!
More baffle pics:
Being couped up all winter I'll tolerate it no prob! Get it while the gettings good!!
Better hot than cold.
Word
Currently the bass bin is 38 liters and tuned to 34 Hz. I'm going to try a lower tuning frequency and see if I like how it sounds. Blue is how it models as is and pink is tuned to 28 Hz.
It'll probably be fine, you have to factor in room gain, so a mild roll off from a lower tuning usually works pretty well in real life.
Our dew point hit 81 yesterday. Even though I have router work on tap, I'd rather splay out in the basement and dream of shoveling snow.
Wow....
Just clamped the baffles on:
I was able to flush trim the cabinets after work today. I realize they look really short and squatty right now. I think their proportions will look way better after I machine the 1-1/2" roundovers on the baffles' sides.
Is particle board easier to work with? Seems like alot of you have switched from MDF. The dust alone from MDF is worth switching away from it.
We’re all a bunch of cheapskates. D1PP1N
https://www.jfcomponents.com/
Looks like be about half price for particle board vs mdf on menards website. I found this too 1.125" thick and enough for 2 baffles in most cases for $7. https://www.menards.com/main/doors-windows-millwork/staircase-systems-parts/stair-treads-risers/dakota-trade-ready-to-finish-particleboard-1-1-8-x-11-1-4-stair-treads/partbdtreadblns4164609/p-1444428255279-c-1531492797420.htm?exp=false
I use those stair treads exclusively for most builds now.
Behind the Green Door:
So my go to SpeakON 4 pole connectors and the recently 3D printed aperiodic vents...
I like the 3/4" thick particle board shelving. I grab some 11.5" wide x 48" long boards when they are on sale. They make saw dust instead of nasty powder....
Yes cleanup is definitely easier.
Clean up is important MDF dust gets everywhere. I moved recently and I promised Ashley, she would always be able to park in the garage. So I will likely have to setup most of the shop stuff in the basement aside from the table saw. The speakons are nice for doing crossover work.
I try always to use the router outside, even in the winter > a hoodie and thin work gloves (and a mask). And X winter, just roll the table saw outdoors.
