Midwest Audio Club drivers.
14567810»
  • I have used the WIIM eq function to help with some of my design work its pretty good; I also like that I dont have to have another component in the stack.
  • I haven’t even messed with that portion of the wiim yet, but I’m interested in trying it. It’s a nice tool to have to see if what you’re hearing is at the frequency you think it is. On one hand I love having a bunch of gear on the rack but on the other hand I think to myself at what point does adding extra stuff to the signal path hurt performance. I can eliminate 2-3 things with the wiim.
  • I cut some colored sticky note strips and stack them atop one another to dim the brilliance of LED's on some amps and it looks much better and much smaller/refined. Give it a go,
    Are those SEOS-8 waveguides I see over 8" woofers?
  • They are the seos 8 guides but the paper 10 inch Dayton RS woofer.
    Steve_Leerjj45
  • I’m an old-time fan of GAS son of ampzilla
    Those great sounding amp, was tempted to get one again, had one in 2005 or so when had gear swapping addiction. Then fell into diy amp building for a decade+
    Wonder if the Fosi one better than, or just the same, as the Douk one. I had hard time getting needles sensitive enough for lower listening volumes and I tainted my mental state swearing I could hear slightest change to sound though would think meter measurement tapping the speaker lines vs inlined - dont know nor sought answer.
    Within last year or so, acquired 2 diff proceed amp5's, discounted more than usual because beat up exterior and one had 1 channel down... Converted one to 3 channel for fam room, and other as 2 channel in office having 3 modules in a box as backup modules. Mostly monoblock'ed channels, though 2 of the toroids multiple secondary windings for front and rear channel with rear channel removed. Not sure how these things only rated for 125w@8 given they have 72v rails and 5pair output devices - normally 70v range would be around a 200wpc@8.
    6thplanetkenrhodesTom_SKornbread4thtrySteve_Leerjj45D1PP1Njhollander
  • That thing looks BEEFY!
    Also, the MAC drivers look way better in person than in the pictures.
  • @jr@mac
    @hifiside
    It looks like current stock of the MAC drivers is pretty low, are there plans for a new batch?
  • There’s still plenty. I update the inventory as needed. Which reminds me that I need to do that. I’ll be reaching out to JR soon like I normally do. If you ever need more than what is posted on the website, you can always get a hold of me on here.
    a4eaudiokenrhodesjr@mac
