Barium - Small two-way with Atlas ribbon and SB ceramic woofer.
edited June 15 in DIY
Named from the Greek word meaning “heavy,” Barium is a soft, silvery-white metal. This small ~ .25ft^3 two-way will feature the recently released RAD Atlas AR120 tweeter paired with the SB Acoustics SB12CACS25-4. Cabinet dimensions will be 11.5" tall by 6.5" wide and 10.5" deep and will feature walnut sides, oak tops/bottoms, and painted front and rear baffles. The woofers were exercised today with hopes of some basic T/S data collected soon. Cabinet pieces are in the process of being cut. The baffles will be .75" MDF while the tops and bottoms will be 5/8" scrap oak flooring. The sides will be a sandwich of 1/2" particle board and 3/8" walnut. More to come...
  • Cutting and trying to flatten a bit of cupping in the walnut.
    kenrhodesSteve_LeeGowaani_101johnny5jzTom_Sjr@mac6thplanetrjj454thtryand 2 others.
  • Baffle CAD with 1/2" chamfers.
    4thtryrjj45Steve_Lee6thplanetjohnny5jzani_101
  • edited June 17
    Glue up has started.
    kenrhodesjr@mactajanesWolfrjj45Steve_LeeTurn26thplanet4thtry
  • Each and every speaker project reminds me that I'm not much of a woodworker. After struggling with getting the top, bottom, and sides squared up I was able to glue up the first one and flush trim the walnut.
    4thtryjr@macjohnny5jzSteve_LeeGowa6thplanetugly_wooferrjj45EggguyTurn2
  • Your not the only one. I'm just getting better at covering up issues.
  • Me too. A master woodworker told me "Just make it look good from 6 feet"
    tajanes6thplanet
  • Unless you are feeding your family from the work, the result is all that matters.
  • I like your choice of wood.
  • That's looking pretty good to me!
  • First final baffle off the CNC.
    Steve_Lee6thplanetugly_wooferKornbreadtajanes4thtry
  • Curious if your top panel feathers a bit after some stain/finishing.
  • I effing love using a CNC for baffles. I often made booboos with a router.
  • I appreciate the comments, let's hope the glue holds :)
    I had to calibrate the CNC as my Y axis was right on, but my X axis was a just a bit short. I'll be doing hard wax oil for the finish. I'll shellac the MDF and then paint it.
  • Which hard wax?
  • edited June 25
    rjj45Steve_Lee
  • This wax. Started the second cabinet and glued the back on the first.
  • edited June 26
    Thanks. Had not seen that product.
    I have used a lot of Tried and True finishes.
  • Just direct wax, no other sealer? I use hard wax, but once I have sealed with shellac or a water based finish like generals
  • Yep, from what I understand, the hard wax oil needs to soak into the wood. Flush trimming the back on one and putting the other side on the other.
