The Quarters
124
  • Drew has some good advice. It will take a long flush trim bit with a top bearing. Spiral bit is best but expensive. You could also try a mirror cut for the final pass with a non bearing bit. I think I bought one from Chinazon for less than $60. Clamp the slabs down with a gap slightly less than the bit diameter and machine both faces in one final pass taking special care to keep the router base tight to the straight edge because it will try to pull away.
  • I have used Unistrut screwed down to a bench top and trued using a string and a circular saw to cut a true edge before - it works well.
  • I've done the mirror cut with a circular saw blade. Just use a thick wide tooth blade not the thin kerf.
  • edited November 2024
    ^ "Book-matching" grain patterns?
  • It's now 2025 and we have been moved in for a few months. I mentor a high school robotics team and the new game for the season is released just after the new year. We have a few months to design, build, and program a robot before competitions. So with robotics and a five year old, there isn't much time for hobbies. I was able to mount the audio rack in the basement that will house all the electronics for the Quarters.
    kenrhodesSteve_Leetajanes
  • The Quarters will replace the Google Nests in front of the windows
    Steve_Leetajanes
  • Whoa! Is that a Flexcore 1st floor (basement ceiling)?
  • Nope, plain old sheetrock.
  • Where do live? My buddy, Adam and his son do the robotics thing here in Louisville KY. Their first competition is in Huntsville Al, this weekend.
  • Northern suburb of Minneapolis - mentor for KnightKrawler Team 2052. Good luck to them at the Rocket City Regional! Based on the list of teams attending, I'm guessing they are Team 2783 - Engineers of Tomorrow?
  • Wish they had that stuff in late 90s early 2000s.
  • Wish they had robotics in the early/mid 80's... but we barely had computers back then.
  • Commodore 64 was my first computer exposure. I bet I was 7 or 8, and it was around '86. Good old 5.5" floppies.
    Irondale HS? My mom's first job out of college back in the 1960's was teaching English at Mounds View.
  • Yep, Irondale! My dad and his siblings graduated from Mounds View in the 50s/60s. Mind if I ask her name?
  • Virgene (Grack) Sehlin. She and my dad got married after her first year teaching.
  • Thanks Scott, I'll have to check the old year books and ask my Dad if the name rings a bell. She taught at Mounds View vs Irondale, correct? Small world :)
  • To provide some context, here is a finals match of this year's game challenge Reefscape. The first 15 seconds the robots move autonomously with pre-programmed code and then the remaining 2 minutes and 15 seconds are driver controlled. Teams are trying to score 4-in PVC called Coral onto the reef as well as move the green balls called algae into the net above the barge where robots will climb at the end of the match.
    Steve_Lee6thplanet
    Correct.
  • edited March 11
    You can watch the competitions live on Twitch
    https://m.twitch.tv/firstinspires/home
    Their second tournament is in Cincinnati, pretty cool to see live in person.
    How'd your alls team do?
  • The Blue Alliance is great for looking up event and team info as well as watching matches via the gameday tab. We competed in Duluth week 1 and finished quals in first, but got knocked out in playoffs.
  • Scott, I work at Mounds View and found these in the archived yearbooks.
    ScottSjr@mac6thplanetSilver1omo
  • Those are both my Mom. Great find!
    jr@macSteve_Lee6thplanetjhollanderEggguy
  • The rack build out has started. The WiiM Pro will be the source and I verified the remote works from upstairs. Optical out to a Hifime S2 Digi that's connected to a pi 5 running CamillaDSP. The pi has a DAC8x for 8 channel analog out, 6 of which are needed for the active 3 way Quarters. The DAC8x will be connected to two AMP-3210T (one per speaker).
    Steve_LeetajanesSilver1omokenrhodesTom_S
  • Second AMP-3210T installed and fully wired in rack along with speakON wall plates. Initial system testing and tweaking of CamillaDSP with some expendable Jamos in case something went sideways. Now connecting DXT-Max (active 2-way) for further CamillaDSP fun.
    tajanesSteve_Leekenrhodes6thplanet4thtryrjj45Colonel7
  • Nice chair! I was totally eyeing one like it on AliExpress😎
  • How are you getting from the WIIM to the amps and how do oyu turn them on - there doesn't seem to be any trigger on these - looks like a good value solution for HT/ATMOS for a lot of channels and power.
  • saw the earlier post - you are not going into these balanced.
  • Hi Ani, the Crestrons are always on, but have auto sensing and go to a low power state. Before I bought them, I was planning on using one of these to power on amps from the WiiM trigger. Yep, grounded the - signal for unbalanced.
