Morel Chubby faced eggs
145679
  • Looks great. Now you can pick up the new OmniMic 40K and compare your single channel model to a new and improved loopback model! Tell your wife that you need to do the full spinorama; I'm sure that she will understand! B)
    I used four 55uF PP caps instead of electrolytics on my Micro Grands mids. But I got them cheap. They were on sale for $2.48 each at Newark a few years ago. I paralleled them for 220uF, so only a total of $9.92 per side. If I did not have these cheap caps, I probably would have used electrolytics.
  • edited March 2025
    @Eggguy said:
    ... How many of you out there in speakerland would use electrolytics anywhere on the woofer? Remember this is not a budget build.
    Some 100uF caps at PE -- NPE $2; Dayton DMPC $30; Audyn Q4 $40; Jantzen Standard-Z $82.
    At JF Components 2 x 47uF ($6.19 each) = $12.20
    I'd go with JuleFidelity in parallel if it were me.
  • I will use electrolytic caps on woofers below 500 Hz. I've been known to use electrolytic caps with a bypass cap above that. I use larger inductors to avoid bigger caps on woofers.
    What's your impedance look like?
    Or is that your impedance in the last pane? If it is, you have a very resistive 3 ohms in the woofer, or I'm reading it wrong.
    Z min is 3.28 at 500 Hz
  • I have all the parts, I am just concerned they might not fit. C10 has a great effect. C16 seems to have the least effect as far as tolerance goes it can vary quite a bit. and C14 can also vary quite a bit without significant effect.
  • edited March 2025
    I normally don't lose too much sleep about using an electrolyric cap in the shunt section of a woofer LP filter, especially when there is also some added series resistance with it (typical). You can model it in most sim programs by adding a series 0.5 to 1.5 ohms. It usuallly doesn't change the transfer function, FR, or phase very much. That said sometimes it does. Example, I used an Audyn Q4 68 uF cap in my Keramiska project because it did negatively affect the sound. That added almost $50 to the project but in that case it was totally worth it.
    jr@mac6thplanet
  • edited March 2025
    @Eggguy said:
    New crossover. I keep going steeper slopes. This one is LR4 at 1480Hz and I can no longer hear woofer ringing. How many of you out there in speakerland would use electrolytics anywhere on the woofer? Remember this is not a budget build.
    I would an electrolytic for the 470uf and poly on the rest, mostly because of space requirements, but that's just me.
    She would be fine with me spending $9.92 times 2, but 500 bucks is difficult for a guy to justify, especially when he is still struggling with the technology that he has.
  • ApexJr has 100uF caps for cheap if that helps.
    I'm with Nick on this one. Poly except for the 470uF. The Jule or Q4 should be fine otherwise.
  • I still do not know how to voice a speaker. I trust my omnimic to a certain extent. I am thankful to have a good room despite it being narrow. I am also surprised that I can detect things that irritate my ears and can address them. I guess that is just my fault finding nature. It can be useful on rare occasions. Very rare.
    I got one buttoned up, I put a 100 uF electrolytic in the parallel trap, or whatever its called. There is no 470. Its a .47
  • The only issue I worry about with an electrolytic in the LP as a shunt is the possible change in value over the years. But if you're still alive, you can always recap the speaker after a decade or two.
  • I think Tom just called you old. :p
    jr@macSteve_Lee
  • I suppose I had that one coming
    jr@macSteve_Lee
  • I appreciate it, but I need no additional reminders.
  • If they are only calling you old they must like you, you should hear what they call me ;)
    Steve_LeeWolfugly_woofer
  • I'm in no position to call anybody else old! I'm thinking more of me and my present age - which often surprises even ME.
    FWIW, this week's video from Kevin at Skylabs Audio (who is 11 years younger than me) was titled, "When I Die, What Happens to My Massive Collection?"
    You are "voicing" your speakers. By stating "I am also surprised that I can detect things that irritate my ears and can address them"
    ugly_wooferEggguy
  • How about that.
    jr@mac6thplanet
    +1
  • New crossover, haven't tried it yet but it is simpler. Got rid of that parallel tank. XO is now 1280 ish
  • Six pack, help yourself
    tajaneshifiside
  • I am giving a bit of priority to power response. Also I am giving priority to above tweeter axis.
  • So I guess in order to get some feedback I need to be more provocative. I think that the depth of a reverse null is not important. I think it only shows what is going on at one position at one frequency. Like judging a pig by a thin slice of ham. That's my analogy.
  • The Pig might have something to say about that ^.
    Keep going, man . . .
    Eggguy
  • Total radiated power. Thats the stuff we hear in the back row. Oink
  • @Eggguy said:
    ...I think that the depth of a reverse null is not important...
    I'd only change this to "not that important". If I could have a deeper reverse null with no other difference, I would prefer it because it suggest the phase alignment is better. If I could have a deeper reverse null but I have to sacrifice on-axis response, or off-axis, or power, I'd have to weigh the tradeoffs and I don't think the reverse null would get that much weight.
    @Eggguy said:
    ...I think it only shows what is going on at one position at one frequency...
    True, but it is not one RANDOM frequency. It is at a specific position, the crossover point, where we would like to have as-good-as-possible phase alignment (subject to tradeoffs).
    Steve_LeeTom_S
  • edited March 2025
    I agree, It is not random, however it is something that I must confess is easy for me to fixate over.
  • I think overlapping or parallel phase tracking above and below Fc is more important than the shape or existence of a reverse null. Odd order filters will have parallel phase tracking (90 degrees out) without a null. Even order filters will have overlapping phase tracking and a sharp reverse null. Like ghostbusters, don't cross the streams.
    Steve_LeeEggguy
  • Every time I attempt to simplify my crossover without degrading phase tracking or power response, my XO point gets lower. My next attempt is around 1250. I will build it and do A B comparison to my buttoned up egg. I hope I don't burn up my tweets with no ferrofluid.
