New Rabbit HOle
2
  • @PWRRYD said:
    Hmmm? This thread has piqued my interest! Looking at all the drivers I have just sitting on my shelves collecting dust, and how cheap those Menards shelf boards are.... I might do some similar experimenting. I'll try it with way cheap drivers and go three way. Up firing Omni woofer, OB mid, and soft dome tweeter. Worse case I will waste < $15 worth of shelf board.
    ...not a softdome....but.... yeah.
    jr@macSteve_LeehifisideNicholas_23PWRRYDtajanesrjj454thtry
  • Looks like some of Eric's work . . .
  • edited October 2024
    Made a 1.0cu.ft double walled 3/4” cabinet (40lbs.) for my rabbit hole adventure. Crazy how much the cabinet rings when the driver is turned around. This should cut back on that .
    Nicholas_23Tom_Sjr@macTurn2tajanes
  • Coincidentally I was contemplating something like this using an 8" poly GRS. Not sure what tweeter I would use, however.
  • I'm buying some shelf boards on the way home tonight =)
    Nicholas_23jr@machifiside
  • If the cabinet rings when the driver is firing into it, shouldn't that be the exact same force as when the driver is firing outward?
    tajanes
    Lots of ideas investigate - maybe too many if you Google omni speakers. I think Bill is already half way there if he tips his side towers up on end and does something like this.
    6thplanetWolftajanesSteve_Lee4thtry
    The motor structure might mitigate that to an extent. Should be more turbulent.
  • Well, there’s a reason why Walsh lined their cabinets with lead. I will post more of my findings that I found this morning on some experimental measurements I’ve done after I done going under the knife today.
  • I changed to simpler and cheaper design for measuring. Mac05 & Dayton ND28. The crossover was done on the fly which only took me about 20 minutes to get it to this point.
  • Graph looks amazingly good considering the setup looks like a diffraction nightmare.
    Probably no worries about baffle step with this sort of thing?
  • There isn’t much baffle step in it. Low end bloat I think will be a problem and good clean midrange.
  • That dip at 1k is the baffle edge. When I turn the cabinet 90 degs that smooths out into 2 smaller dips.
    tajanesSteve_Lee
  • Wait - under the knife?
  • Ahhh the old snip snip. Good luck!
  • All done. Took about 20 mins
  • That's not too bad, have a few uncomfortable days and good to go.
    I hear a bag of frozen peas helps
  • Just don't go golf 18 holes tomorrow. A guy I worked with did that. Big Mistake! Couldn't walk for a week.
  • Yes frozen peas. Probably don’t open the bag tho.
  • All good. IBUPROFEN works great.
  • From the sounds of it the bag has already been opened. Oh you meant the bag of pees.
    Silver1omoPWRRYD
    This makes me think of:
    When the moon is in the Seventh House
    And Jupiter aligns with Mars
    Then peace will guide the planets
    And love will steer the stars
    jr@macSteve_Leerjj45PWRRYD6thplanetugly_woofer
    I went down that road a few nights ago looking at all the google images. Since im inexperienced here im start simple.
  • This really gets me trying to contrast/ compare 2pi to 4pi of a ‘conventional’ speaker vs. dipole vs. bipolar in-room responses. Thinking the OHM style being an almost perfect bi-pole? Not to mention the unthinkable 901s…
  • On those duval speakers the only frequencies that are diffracted are those below the diameter of the ball. Which makes for an interesting xo
    tajanesWolfrjj45
  • When I did the MM 2" jobbies, I used a diffractive/absorptive mix that seemed to work pretty well. I used a stuffed whiffle ball style semisphere about the same diameter as the Sd calculation, placed fairly close to the cone. It seemed to load down to about 1k, which was beneficial.
    I have some pickle balls and a large Styrofoam semisphere pair that I plan on experimenting with along these same lines.
  • More ridiculousness to come.
