New Rabbit HOle
Waiting for some cabinet coating to dry so I thought I would come up with a new rabbit hole to go down. Let me say so far I don’t hate it!
silverDrjj45tajanesBillet6thplanetugly_wooferPWRRYDWolfNicholas_23Steve_Lee
«13
  • You didn't waste any time on that ohm walsh concept!!! Why isn't the tweet omni?
    It isn't in the Walsh, either.
  • Marvin said it was an omni tweeter but there was some damping behind it to reduce the amount of rear wave. Unless I misunderstood him which is entirely possible given how I was feeling.
  • I htought the ohm was omni throughout - no idea as all I could see was the cage - didn't look it up. Will do so now.
    There was felt pad like think surck on the cage though partway
  • Where did you cross them over?
  • Eitherway that upside down satori reminds me of this speaker
    6thplanetWolf
  • I believe this is what Marvins look like inside tweeter mounted on the magnet just like mine is.
  • Needs more cardboard
  • From what I’ve read, the tweeters are towed in about 30° tilted up like 7° but I only have one right now just to see if it’s even feasible
  • A very similar Ohm tophat that Leo Frank used some 10 years ago now did not have an omni tweeter. It was a direct tweeter and omni midbass. I'm sure there were different models of tophat that operated the way suggested by controlling radiation patterns as well.
    This is one theme idea InDIYana has not had yet that I find quite interesting. After doing the Mindblowing Minisculities with the Goosebump woofer module, I was really surprised at how good that setup sounded. I've long thought about a Duevel Planets style 2way build, but have not done one yet. Either that style or inverting the midbass seems the most inviting. I know Dan Neubecker did quite a bit of experimentation with the concept and I'd like to develop my own take on something omni oriented.
    This is an open back Beast mode at around 2.1k. Just trying different things.
    Nicholas_23
  • The only bad thing about the Satori 5” is that notch at about 1.8k. The way it sounds does merit me to look though my pile for something different and measure.
  • edited October 2024
    Cool experiments for sure Brad.
    It would be super cool if you could pull off something like this with regular DIY priced drivers (us darn DIY cheapskates). When I see the word "Satori" I think Yikes!
  • Shit, I was thinking Illuminator.
  • Hmmm? This thread has piqued my interest! Looking at all the drivers I have just sitting on my shelves collecting dust, and how cheap those Menards shelf boards are.... I might do some similar experimenting. I'll try it with way cheap drivers and go three way. Up firing Omni woofer, OB mid, and soft dome tweeter. Worse case I will waste < $15 worth of shelf board.
    hifisidetajanesjr@macTurn2
    I agree that it feels like something is missing, same for the 7" too.
  • 3 way would be much simpler I think. The port noise on this one needs some attention.
  • Gears are turning... darn rabbit holes! lol
    hifiside
    I had this running through my head also. I think there would be some great advantages to this design.
    rjj45tajanesSteve_Lee
  • Your sketches look a lot like mine or maybe it's the other way around :)
    hifiside
    Not that particular sketch regarding this project idea. Just our sketches in general.
    hifiside
  • If motor noise is a concern you could go with a 3-way. if the mid was only working 200-2.5k then the motor movement would be limited but the Omni affects should remain the same. I built a modified version of the Linkwitz Pluto and was impressed with the results using a minidsp HD.
    The Pluto for reference:
    Steve_Leerjj45
  • They would be great. Uglywoofer made them sound terrific. There heavy and expensive would be there downfall.
  • @hifiside said:
    ...expensive would be there downfall.
    Yes, that are usually listed as $250 each. But they often go on sale for $250 a PAIR which isn't outrageous.
  • @Nicholas_23 said:
    So what if a guy were to use a ESS large AMT up top vs the conventional dome the OHM's came with?
    That should work exceptionally well for this design
  • I use to have a pair but sold them in Iowa a few years ago. I believe I had the mid sized ones.
  • After hearing uglywoofers pair I’m sure I will be looking for another set soon. I’m gonna try some cheaper drivers for now and see if I even like the sound when I make 2.
    My father even asked about me trying an omni build a couple times. The ohm style 2-way always came to mind. Definitely interested in what you come up with!
    Hmm I do have a couple pair of SDS-160F25PR1s and a pair o spare beastmodes. Clamshell iso could work for bookshelf size.
