The most coveted vintage gear
1246
  • This is my Hafler DH500 amp. It's about 35 years old and I had the electrolytic caps replaced along with the bias and offset pots 6 years ago. It weighs 45 pounds.
    PWRRYDrjj454thtry6thplanetScottS
  • Very nice !
  • That's the real deal!
  • But is it 4 ohm stable, Ron?
  • edited September 2024
    I'm not Ron but I've had Hafler's for about 35 years and still own a 220 that easily powers any 4 ohm load I've thrown at it. I've also done the same mods Ron listed and did a complete rebuild on an XL280 with Musical Concepts boards, caps and dual power supplies.
    I still highly covet Hafler amps.
  • I've known a DH200 to be 4 ohm stable, but never saw the actual spec sheet like above. I know back then 8 ohms were normal, and speakers were in general more sensitive too. I was just curious..
  • That's a beauty, Ron! I've always wanted a big Hafler, but never found one locally that was in such pristine condition.
    From the internets: "In 1981 the audio magazine Stereo Review bench-tested one for an article and recorded it clipping at 434 watts into 8 ohms. Dynamic output was 792 watts into 4 ohms and 653 watts into 2 ohms. Not too shabby!"
    I ran a pair of 2 ohm ribbons with it for years. They were fused with a 3 amp fuse so the amp never got close to full output. I found a few references over the years that said you could weld with it.
    Steve_Leerjj45jr@mac4thtryugly_woofer6thplanet
  • Ron, nice unit. Now you have to pop the cover and show us the big engine! I think this one has a big heat sink tunnel type config with a fan on one end, like the Ampzillas, right? I'd imagine that with a 2 ohm load, the fan would kick up to high speed to keep the outputs cool? Or maybe the fan stays off most of the time.
  • I found this picture on the web.
    The fan is always on but at idle it is very quiet as in put your ear next to the amp to hear it quiet. It was always outside the listening room when I drove the 2 ohm load and I doubt that it ever ran hard enough to kick the fan speed up. The ribbons were 91db/1w in an active system so it didn't take much to get them loud.
    4thtry6thplanet
    Sorry Wolf, I fat-fingered the previous post. It's a 220 rather than a 120. Sorry about that!
    Jim
  • My DH200 is still going strong since the overhaul in 2020. It only gets shut off when I leave for vacation.
    https://diy.midwestaudio.club/discussion/1484/hafler-dh200#latest
  • I've never thought to leave an amp on all the time. Does it pull much current at idle? I know many people leave all their gear on 24/7 and pro amps in many installs stay powered up for decades.
    I leave the dreadnaught on and probably shouldn't. It's biased pretty high into Class A and just sits there and heats the space.
  • Not exactly a piece of hifi gear but our paging amp at work had been on continously for the 10 years I've worked there and I don't know how many more years before I started there. It looks like it's from the early/mid 2000's and is class AB. Put my hand on it once and it wasn't even warm to the touch. Makes sense. I had a professor tell us that heat cycles and inrush currents are what's hardest on electronic components.
    BilletSteve_Lee6thplanet
  • When I started at the TV station in '85 there were racks of old B&W tube monitors, test equipment, and video & RF gear that had been running continuously for decades. The racks were built into a long wall in master control and the room behind them had AC pumped in & aimed right at the racks. I was told they rarely needed any maintenance because they were never power cycled and kept nice and cool. I do remember always bringing a sweatshirt with me even in the Summer because they kept it so cold in there.
  • Yeah, that amp is in our IT room with all the IT servers and it has a dedicated mini-split AC unit that keeps the room at a constant 70F. It's also on a UPS that is fed by our 45Kw backup generator. Livin the good life :)
  • Yeah, in rush current and power cycling is why I just leave it on. It's a little warm sitting there.
    In addition to what has been said above, I've also read that high humidity is also a destroyer of electronics and circuit boards. Like storing a piece of equipment in a cold and humid basement is not a good idea. So if you leave a piece of equipment on 24/7 and it gets slightly warm, this lowers the relative humidity in the immediate vicinity around the circuit boards.
  • That is true Bill.
    I never even thought of that. We played some pretty dark, damp dives back in the day, but didn't dare leave the power distro connected if it was a 2 nighter.
    The vintage guys may be awakening to modern drivers and materials. (And they've begun selling Wharfdale.)
  • My parents have a pair of L710 that they bought when I was a kid that still look and sound great.
  • I would hope they could design a better speaker, considering all the advances in the software over the past 20 years. It does make my brain hurt to see the mid & tweeter mounted side by side like that.
    Steve_LeeAnalogkid4556thplanetTurn2
  • Obviously not ideal, however depending on the crossover point the effects in the listening position might be negligable. There are also a large group of people that lay their speakers down. If horizontal placement was considered during the design process it might be the best compromise to maintain tonality between the two orientations.
    I'm going to get my flame retardant suit. 😜
  • Those look like ADS L810 on the left, which are no slouch and sound great. The imaging does not suffer in this instance due to close position and bandwidths- as long as they are mirror imaged.
    The Wharfedales sounded okay at Axpona.
  • Good to know. Not every manufacturer got it right back then. I'm looking at you Sansui!
  • No doubt!😆
  • Stumbled across these at my local Habitat Re-store. A pair of vintage Optimus - 7's. These were Radio Shack's flagship back in 1974. Cabinets and grills are in very good shape. Light scratches here and there, but very easy to buff out and restore. I've read over on AudioKarma that these speakers are quite rare and certainly worthy of some serious time and effort to repair or restore. Unfortunately, all the drivers in this pair have been replaced except for one of the two big woofers. They want $95 for the pair, but I think I will pass. The cabinets alone are probably worth the asking price, but it would be very difficult to source a complete set of original drivers. I'll let somebody else grab them. Bet they will be gone within a week.
    rjj45hifisideTurn26thplanet
  • Wow - I don't remember ever seeing those, but I was only 11 in '74. But I do remember a number of what I can only call "end table speakers"
