The most coveted vintage gear
2456
  • The 5050 should be a great piece for that price. Looks fairly easy to service. But the 5000x is no slouch. I rebuilt it's little brother, a 2000x that I picked up earlier this year. That thing is the poster child of early 70s affordable HiFi. The 5000x looks a bit more stout, with split power supplies and a larger transformer.
  • Should I make an offer on one of these?
  • I sure would. But not everyone is a crazy vintage collector like me.
    It's a tough choice between the two. The 5000x was the TOTL back then and some of the AKers say it compares to the early McIntosh sound. I stand corrected on the split power supplies - it has cap coupled, quasi-complimentary outputs. It might need some caps replaced. My 2000x sure did.
    The 5050 is ~1/2 the power, but some say has tighter bass. That makes sense, seeing that it has no cap on the outputs. You really can't go wrong either way - choose the one you think looks the best.
  • I'm partial to Sony and my TA-F6B integrated and PS-50X turntable. I know it's not the coveted TA-F7B with VFETs but then again I don't have to worry about replacing transistors you can't find anymore and it still sounds great. Same with the 50X, not top of line 70X but less to go wrong. Sony just has a way with design.
    6thplanetSteve_LeeGeoffMillarTurn2R-Carpenter
  • I'll probably pass on these receivers as I'm
    1) not a collector of old gear
    2) don't really need a receiver because Rockford radio stations suck
    Ed_Perkins
    That's an awesome looking amp! I've never even seen one of that series in person.
  • The only thing I have that is "vintage" is an old Onkyo integrated in the garage. I like it because it is 4 ohm stable and has no problem driving the old garage speakers.
    Tom_S
    Thanks, they were made extremely well. I don't think Sony gets the credit for the incredible stuff they made in the 70s. I had a slightly older Marantz 2245 and there simply is no comparison in quality or design in my opinion,
    www.thevintageknob.org/sony-TA-F6B.html
  • edited April 2024
    I picked the SX-1250 up on Saturday. I haven't even carried it into the house because it smells pretty funky. It's in worse shape than any piece of gear I've ever purchased. I picked up an old Pilot receiver with blown outputs for $30 last year that was pretty filthy, but this 1250 has it beat hands down. I got the Pilot running, so there's hope for this one too!
    ugly_woofer4thtrySteve_Lee6thplanetGeoffMillarhifisideTurn2
  • There's a metric ton of stuff going on that faceplate! Holy buttons Batman!!! :p
  • Hey Tom, you think that looks bad, take a look at this. I found this classic amp at my local re-store marked "SOLD AS IS - NO RETURNS." Circa 1969. 60wpc. Kind of beat up looking. I figured, hey, only a few bucks, might as well take a chance and see if I can get it working again.
    I checked the fuse and it tests good. Popped the cover. Very thick layer of dust and grim. I tried to lightly brush some of it off, but discovered that the "dust" is almost "burned" into the surface. Found a few leaky/bulgy power supply caps that need replacing. Tested the xformer primary and secondary. No opens or shorts. Pulled and did a simple diode check on all output and driver transistors. All good with no shorts, but the socket pins are loose and they need new mica pads & heat sink grease.
    My guess is that re-store employees could not test it because the power cord was missing and they could not find a replacement to fit the unique AC power inlet on the back. (see pic). Plan is to finish checking all parts, re-cap the power supply, and then slowly bring it up with variac and dim bulb.
    6thplanetNicholas_23ugly_wooferjhollander
  • Wow, I bet that could tell some stories!
  • That's a cool old piece! Was that thing stored in a barn? Glad you rescued it. Those knobs remind me of something...like the HK Citation Eleven? They are very similar.
  • I bet the lack of power cord saved it from becoming trash before you found it
  • I'll show you more of the carnage once I have it in the house, but here's a preview. This is what's left of the speaker protection relay.
  • Where is the coil and case?
  • Good question! It looks like somebody thought they could fix it and may have started a repair or refurb. The power transformer bolts are missing and the main caps are disconnected underneath. Likely left it in a dirty garage and some kid decided to take the wire cutters to it. They pried the bottom cover up while it was still attached on one end. I really hope they didn't cut things up too much. It's a bit of a mystery. An adult wouldn't do this kind of damage.
  • @Tom_S said:
    ...An adult wouldn't do this kind of damage.
    Your adult friends/acquaintances must be more responsible than mine. ;)
    Steve_Lee6thplanetKornbread
  • edited April 2024
    You ain't seen nothing yet, hold my beer!
    Probably not. Does not smell like a barn. No cigarette smell either. It almost seems like it was used for many years in a very dusty environment and then sat idle for about 10 to 15 years in an outside storage shed. The slow temperature and humidity shifts over the years probably "baked" the dust onto the components and PCB boards.
  • The most vintage thing I have is a Nakamichi TA-2A.
  • That Stasis gear is sweet! I know Nelson Pass had a hand in designing some of the power amps.
    Analogkid455
    Yes, and it sounds really good. Comparing it to my Yamaha AVR, no comparison.
  • I too have a Nakamichi Stasis TA that's on loan to my brother. I'm mostly interested in streaming audio players and class D stuff, but was gifted these well used items:
    Denon DCD-520 CD player
    Philips 673 tuner
    Pioneer A-91D
    Tom_SAnalogkid455
  • Starting the restoration of a near mint Marantz 2275. My buddy seems to find all kinds of nice gear while traveling for work. He has brought me a few beat up doorstops too! Waiting on some parts, but I do have everything on hand to rebuild the power supply board.
    4thtryScottSjr@machifiside6thplanetTurn2ugly_wooferjhollanderGowaMikegand 1 other.
  • edited June 2024
    Wow! I suppose you have to be extra careful when working around a classic like this. Good luck with the power supply rebuild!
  • Yeah - I took the knobs and face plate off and stashed them out of harms way. This one should be pretty easy. The amp boards and tone/amp board just unplug!
    6thplanetNicholas_234thtry
  • That's a ton easier than some of the rats nest connected old gear.
  • I grew up in the 60's and 70's, so I remember drooling over some of this gear on the shelves at some different retail outlets. I started collecting some a few years ago and have picked up some nice gear. My favorite is a Pioneer SX950 in minty condition. I got it for $150. The pots all need deoxit'ed, but otherwise she's a real beauty. I have a couple of Marantz receivers I love, A JVC, and a Sony STR-6800. A few others too, but these are my favorites.
  • I'm right there with you on the SX-x50 series. They might not be audiophile grade, but I still remember the entire line on display at Team Electronics. The golden glow left a lasting impact.
    The SX-950 is the only one in that series I still need to find. I can only hope to find one for under $500 that isn't seriously abused.
