Ran out of time to start measuring but setup is otherwise complete:
Tymphany TC7FD-04 in a monolithic 3d printed wedge enclosure, the test vehicle for the printed len plates. CHECK.
Test plate with no loading. CHECK.
Test plate with a simple plug loading. CHECK.
Bass module - vented MAC-6 in a 7 liter madisound enclosure from when time forgot. CHECK.
measurements in the coming days.
Fun project, JP. Look forward to your impressions.
This should be neat.
First measurement of the no-plug faceplate, which given how small it is, I was surprised to see the rather potent boost it gave from 6k to 15k. Details:
Plug plate glued into place for testing:
Same measurement conditions, results:
Can't say that is a winner. but it for sure is having an effect on the loading of the driver from 5k and up.
On the other hand, crossing over to a tweeter at 5k would make it far more viable and it seems to create a waveguide effect on directivity all the way down.
Now I'll imagine more shapes and see what happens.
What's going on on the backside of the phase plug?
Its rounded, about 3-4 mm above the cone dust cap.
Did you make it so you can screw different shapes on the bridge?
https://www.jfcomponents.com/
Nope, printing each time, your idea is better!
Bottom looks like so, for reference of attempt 1:
Brad's great idea, very nice! A spot to slot the separate bar/plug into!
New test prints loaded and printing:
One smaller plug (25mm diameter to 20mm and less depth) plus a couple other "why not" lens shapes.
Will you be able to try the new smaller plug in both directions (point in as well as outward) ?
Good suggestion!
Yes, that should be easily done, good idea
So when taking apart the current plate and attempting to pull out the driver I kind of forgot how much I glued the wire into the back and uh, that was that - oops!
Well at least I have 7 more of these drivers in a drawer in the closet (torn out of the MMTMMW build I brought to Indy ages ago). So I have that going for me, which is nice.
Also, since this is getting for serious, I'll make a more robust box!
A slight pause on measurements though, while I get this all together.
Carl FTW!
I wish I could find my article on acoustic lens/ phase plugs. I was all about making the on axis response look as good as the off axis iirc.
