Acoustic Lens Tests
Ran out of time to start measuring but setup is otherwise complete:
Tymphany TC7FD-04 in a monolithic 3d printed wedge enclosure, the test vehicle for the printed len plates. CHECK.
Test plate with no loading. CHECK.
Test plate with a simple plug loading. CHECK.
Bass module - vented MAC-6 in a 7 liter madisound enclosure from when time forgot. CHECK.
measurements in the coming days.
Steve_LeekenrhodeshifisideSilver1omoNicholas_23jr@macugly_woofer6thplanetsilverDBryan@MAC
  • Fun project, JP. Look forward to your impressions.
  • This should be neat.
  • First measurement of the no-plug faceplate, which given how small it is, I was surprised to see the rather potent boost it gave from 6k to 15k. Details:
    • 24" distance
    • SPL roughly 90db
    • 0, 22.5, 45, and 60 degrees rotation
  • Plug plate glued into place for testing:
    Same measurement conditions, results:
  • Can't say that is a winner. but it for sure is having an effect on the loading of the driver from 5k and up.
  • On the other hand, crossing over to a tweeter at 5k would make it far more viable and it seems to create a waveguide effect on directivity all the way down.
  • Now I'll imagine more shapes and see what happens.
  • What's going on on the backside of the phase plug?
  • Its rounded, about 3-4 mm above the cone dust cap.
  • Did you make it so you can screw different shapes on the bridge?
  • Nope, printing each time, your idea is better!
    hifiside
  • Bottom looks like so, for reference of attempt 1:
  • Brad's great idea, very nice! A spot to slot the separate bar/plug into!
    hifisideSilver1omoPWRRYDugly_wooferScottSBryan@MAC
  • New test prints loaded and printing:
    One smaller plug (25mm diameter to 20mm and less depth) plus a couple other "why not" lens shapes.
    Silver1omotajanes
  • Will you be able to try the new smaller plug in both directions (point in as well as outward) ?
    JasonP
  • Yes, that should be easily done, good idea
    hifiside
  • So when taking apart the current plate and attempting to pull out the driver I kind of forgot how much I glued the wire into the back and uh, that was that - oops!
    Well at least I have 7 more of these drivers in a drawer in the closet (torn out of the MMTMMW build I brought to Indy ages ago). So I have that going for me, which is nice.
    Also, since this is getting for serious, I'll make a more robust box!
    A slight pause on measurements though, while I get this all together.
    Carl FTW!
    JasonPugly_wooferSteve_Lee
  • I wish I could find my article on acoustic lens/ phase plugs. I was all about making the on axis response look as good as the off axis iirc.
