WinISD *Simulate Voice Coil Inductance* Option . . .
Do you guys use any of the options under the ADVANCED settings subtab?
I ran across the subject one trying to get a better modelled response curve for driver Le differences and, voila!
Comments/thoughts/explanations desired.
Thanks!
  • Basic Le as a singular value isn't good enough for accurate simulation. Extended impedance parameters "semi-inductance" is needed for accurate representation of driver inductance, I'm not sure WinISD supports that.
  • If you're interested I can post some instruction on how to extract extended impedance parameters from a driver datasheet and utilize within VituixCAD enclosure modeller.
    Silver1omoSteve_Lee
  • Here.
  • ^ This is awesome of you to put together!
    Thanks, man - I'll need to learn VituixCad eventually . . . I saved the file for the future.
    <3
