Basic Le as a singular value isn't good enough for accurate simulation. Extended impedance parameters "semi-inductance" is needed for accurate representation of driver inductance, I'm not sure WinISD supports that.
If you're interested I can post some instruction on how to extract extended impedance parameters from a driver datasheet and utilize within VituixCAD enclosure modeller.
Here.
^ This is awesome of you to put together!
Thanks, man - I'll need to learn VituixCad eventually . . . I saved the file for the future.
