Walk me through amp project - UCD32MP
13»
  • so while i am waiting for stuff to arrive, i got an reply from another forum from somebodyelse who had build the amp a long time back and he send me the old pdf for this amp.
    it had a recommended buffer in it, page 5 (attached). Help me understand the circuit and is that triangle thingie an op-amp (it's doesn't specify any no). What is the parts list required.
  • edited March 2021
    so i think these are the part list
    Opamp = ? not sure what to try
    100R = 100ohm
    100k = 100,000 ohm
    3k6 = 3600 ohm
    1k = 1000 ohm
    cap is 100picofard?
    what is ground here?
    What is Avbuffer = 4.6, is this some opamp parameter?
  • Yes, those values are correct. The 4.6 is the gain on the opamp. A TL072 opamp would probably work fine for that. A pot could be used where Rf is in that schematic to have adjustable gain. Something like a 5-10k.
    ani_101
