TB 2" Dome midrange issue - is there a way to fix this
edited November 2020 in DIY
I have a set of very old Tang Band 2inch dome midrange, that i had obtained some time back. One measures fine, the other seems off.
Is there a way to fix these? Something i can start off with? what problem does the Impedance curve reveals?
  • The purple trace looks like a pole plug issue or maybe a faceplate that isn't right.
    dcibel
  • Yup, looks like one is leaking.
  • Ok, will try to take apart the purple one and see, if I can see anything
