Safiniea is Greek for clarity and that seems to describe these pretty well. Once again, Rival has produced an absolute gem of a midwoofer with the R176P08. Excellent response, linear, and smooth. This is the first ScanSpeak R2604/8330 I have used on my own and found it quite easy to work with. No real suprises here and nothing concerning about it. As this is a kit for RAD, I won't post the crossover here. It does use a 2nd/3rd order electrical topology that crosses at about 1.8k. I will post more measurements soon. Enclosure is a combination of 3/4 bbply (baffle, top, bottom and brace), mdf (sides, rear) and 1/2" bbply baffle. Port is 2"×6"L fir a 40hz fb. RAD has baffles already cut that will accommodate the Taured 2way and Safiniea builds as well.
+1 on the woofer. I've been listening to just one of my woofers so far, playing full range (no xover), in an ML-TL. Has a very pleasant sounding, silky type midrange. It peaks up quite a bit in the highs for a woofer, but, even so, the highs in the 5kHz region sound reasonably controlled. I will be crossing at 800Hz 4th order.
Wolf beat my reply by 2 minutes! Didn't see his post before I hit the post comments button, so there must be about a 5 minute server processing lag built into the system.
Ignore below 200. At this high level 90db@1m, I am getting some room noise right now. Hopefully taking care of that soon. After some extended listening, I wasn't completely happy with the first crossover and decided to take some additional measurements which also confirmed the room effects. So a little more modeling and now they live up to the name IMO. These will more than likely become the mains for our upstairs system which means daily use.
Mine should be up and running soon.
