Purifi
2
  • ani_101 said:
    Are the amps complete units or require separate  power supplies? Don't know much about amps to tell... but they seem to be 2 ohm stable...
    https://purifi-audio.com/eigentakt/
    The amps need power supplies and there appear to be input buffers boards that mate up to them. Definitely 2 ohm stable from the graphs.  Expensive.
    https://www.nordacoustics.co.uk/purifiaudio1et400a
    http://https//www.audiosciencereview.com/forum/index.php?threads/nord-three-se-1et400a-dual-mono-stereo-amp-review.9938/
  • The amps do not include power supply, their docs say that you can use even basic unregulated smps without performance degredation.
  • edited December 2019
    dcibel said:
    I clicked the Tech page, too, the top 2 Articles were pretty interesting about low frequency distortion and cone mass vs speed.
    The low frequency distortion article was a good read.  Maybe we should be paying more attention to IM distortion and less to harmonic distortion.  IIRC both SL and Mark K. stressed the importance of IM distortion.
  • I'm excited to see the 4", though less so about the 84 dB sensitivity. One thought I've had is to use the 6.5" as an OB midrange along with either a couple SB34NRX75-16s or SDX10s per side, also OB.  If I went that route, I would probably seriously consider putting the TL tweeters (or Bliesmas) in some sort of waveguide so I could cross low.
  • The 4 inch has more than piqued my interest. With the ultra-low HD and claimed low IMD, they are on a short list with the Satoris and maybe the new SB Textremes.
    The midrange distortion caused by BL modulation at low frequencies is just another reason why 3-way speakers are just better, even with less complex drivers ;)
    Or even higher complex drivers ;)
    dcibel
    My wife and I have always preferred 3 way sound, even though I couldn't quote empirical evidence why.
  • It's probably the doppler distortion :)
    It can be difficult to narrow down exactly what the cause of a preference is with a lot of design changes. Moving from 2 way to 3 way will have changes in linear and non-linear distortion as well as power response, even doppler effects, but which one of those changes are the reason why I have such a preference, and which ones are inconsequential side effects?
  • But Chahly - Stahkist don't want speakers that look good, Stahkist wants speakers that sound good!
  • rjj45 said:
    Jeez. I know what drivers I am saving for....
    Which ones?!?
  • Wondering if going 3 way with the 6.5 or 4 would be worthwhile or these becomes strictly 2 ways given the xmax and ability to play low... Would there be a mid range driver???
    ani_101 said:
    Which ones?!?
    Eventually, I (along with everyone else), will build some TMs in small(ish) boxes and marvel at the bass extension and clear mids. I'm on a 3 way "kick" now, and would welcome a SOTA mid (3.5-4.5 inches) for (what looks like it will be) a reasonable price.
    Purifi looks like they have solved some fundamental problems, and should quickly get a lot of market share. I hope that they can stay independent....
  • RJ... On another forum they (Purifi) said they were working on a 95ish db 4in midrange.
  • That should be nice for a there way.
    The current 6.5 should make a killer TM though.
    That sounds awesome!  I take it this is NOT the PTT4.0 (https://purifi-audio.com/transducers/ptt4-0w04/)
  • Glad to see them hit retail! Man, that's one ugly-ass surround. Looks like speaker grills are coming back to DIY.
  • Hopefully they carry the full line...
  • And the surround doesn't look too bad in person...
  • edited June 2020
    That photo makes it look like it was made on the Monday morning the day after the Daytona 500 at a Dodge assembly plant   :#
  • I hadn't seen the rear of the cone until now- that reinforcing V-Ring likely has a hand in the cone edge resonance control.
    The surround is well- yeah- despite being ugly- akin to that of the for-and-aft surrounds that some car audio drivers and Fostex (called UDR/tangential, in FW168HP-X and Sigma series) have had for a couple decades now, albeit a little more extreme in profile.
    Fostex driver with UDR:
    https://www.madisoundspeakerstore.com/approx-4-fullrange/fostex-fe108ez-4-full-range-sigma-series/
  • If you really look at things, speakers want to be massively ugly to produce good sound. Even the enclosure is subject to this.
    BrannigansLaw
  • 6thplanet your speakers are not massively ugly...
    I agree with this to some degree. In rare cases, they can be pretty *and* functional (eg avalon), but others (eg Grimm) and my own attempts to make substantive dents in things like edge diffraction look ok on paper, but when I see them in person, they look awful more often than not.
  • Ha!,thanks. I chose form over function sometimes (most times). You all get what I mean, enclosures want big round overs/ champers, things offset, felt stuck to them, ect... Then drivers with the weird surrounds, proper phase plugs, cone treatments/shapes (yellow ones sound the best to me😛) So we chose where to draw the line to have some visual aesthetics and still sound good. Maybe Ben should do an ugliest great sounding speaker theme?
  • Sorta did that- Rat Rockers back in 201_, not sure the year. Lots of ugly that year.
  • Beauty is in the eye of the beholder, I actually think the mountainous surround looks neat - it makes for very easy brand recognition and a talking point for you to talk up how superior your speakers are to the feeble competition :)
    Regarding the V shape on the backside of the cone, here's an excerpt from the Hificompass interview:
    Yevgeniy  Kozhushko: I think the peripheral circular rib at the back edge of the cone is made for resolving surround-edge-of-cone resonance problem?
    Lars  Risbo: Yes, this is to strengthen the cone rim and thereby to suppress unwanted modes.
