Got this today.... I would have got it to IOWA if it would have arrived last week... but now I am rethinking how I would have lifted it in the car. I am tired and need to take a break just unboxing it.
Anyways as the saying goes, those who can't built, buy.... here are some pictures in the box...
anybody know what to do or any tips before i fire her up? Doesn't seem to have a manual or anything either physical or online....
so i suppose there is no bias adjustment. It has knobs for power, volume and input selection, a switch for integrated or main and voltage selector, no other apparent adjustment mechanism on the exterior.
the amp is musical paradise MP-501, single ended parallel mode using KT-120, whatever that means. It is not push pull but does have 4 KT-120
I opted for the 6SJ7 tubes which were extra and the KT-120, so all in below 1500$ drop ship from china
Yes, you definitely MUST have speakers connected before you power up. I would suggest connecting some cheap speakers, not your best high dollar pair for the first few test runs. If something was miswired or came loose in shipping you don't want to destroy a great driver. With enough B+ voltage and good output transformers a single ended KT150 tube can do about 20 -25 Watts. So with two in parallel probably 40 - 50 Watts @ ~1% THD (mostly 2nd order).
4x rca 6sj7 and 4x tungsol kt120
Thanks Craig for checking. The amp takes the following tubes:
V1 and V2 accept 6J8P, 6SJ7, 5693, 6*8, 717A, 713A and 6SH7 pre-amp tubes. V3 and V4 accept 6J8P, 6SJ7, 5693, 6*8 pre-amp tubes.
I am planning to get a few other of the pre-amp tubes... if oyu have any and would like to part with, send me a PM.
Power Tubes it takes KT120 or KT150. I have a quad of the KT120. KT150 doesn't make a difference in the power rating it seems, it is fixed at 55watts but supposedly is a bit more dynamic and lasts a lot longer than KT120, but that's for later...!
Regards
Ani
Sending PM to you
By the time it cools down then change tubes to it warms up, to cool down to change tube and warm up.... will take some getting used to
I wonder if there's an issue with something like this in direct coupled designs? What happens when you drop in a cold tube that's setting a bias point for another tube that's still nice and warm?
