3M 77 is the shit , laid a layer down on the box and tweed then ran my hand over it to bond everything together. Worked great , thanks for the heads up on this stuff.
Looks good! I love the classic look of yellow tweed.
FWIW I had issues with using Super 77 with Tolex. Tolex is a lot stiffer than any normal fabric, through it does have a fabric/felt backing. I had issues with seams curling up, the Super 77 just didn't have enough stick for it at the seam, which may or may not be a problem depending on the shape you're covering and how its assembled. Super 77 also doesn't ever dry, its just sticky stuff that will still be sticky a year from now. If you're using Tolex and will have a seam on the bottom or back side, I'd probably go with contact cement instead.
Have any of you lacquered something like tweed or similar ? Is there an alternative to lacquer that can be used? I was thinking of putting a coating of something over the tweed. TIA
Up in the air with how this turned out , it does have that vintage look . Contacted my Russian brother for some ideas and also mr.googles . Went with minwax poly pecan for the coating. Two coats all in all . If I were to do this again I would go with the honey tint poly.
