So I was recently testing out speakers with a Class D amp (Peavey IPR-7500) and realized that I definitely need to go back to class A/B. Previously I had used a Peavey CS-800X which tops out at 0.030% THD, but with my AMT's measuring in the 0.2x % THD range, that 0.03% ends up making a difference. I don't even want to think about how much THD the IPR-7500 might have been contributing, LOL.
So, what should I be looking at for an amplifier with < 0.01% THD @ 50W into 4Ω? I don't need anything super power powerful, since it will just be for testing, so 50W would suffice.
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-neurochrome-modulus-286-amp.6443/
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-hypex-nc400-diy-amp.5907/
https://kenrockwell.com/audio/hafler/dh-200.htm#thd
WRT big power amps, I suspect JR is right... however, for a 'known reference', if I were attempting definitive testing, I'd want something that had independent bench tests available somewhere. That's just my inherent skepticism of manufacturers' specs though.
Here ya go:
https://www.ebay.com/itm/Hafler-DH-200-Stereo-Amplifer-Audiophile-Tested-and-Working/173865004047?hash=item287b296c0f:g:ilQAAOSwJxRcqQoy
https://www.ebay.com/itm/Hafler-XL280-Amplifier-in-Excellent-Condition-Great-Sound-w-copy-of-manual/283458344393?hash=item41ff6f15c9:g:16EAAOSwYnhcu4CU
Been using GAS amps for years.
Example.
If an AMT measures 0.2% THD as an average, and the amp may have up to 0.030% of it's own, then the actual THD as high as 0.23%. I want to reduce that uncertainty, but I may not actually know how much unless that specific amplifier is bench-tested.
