https://www.parts-express.com/peerless-by-tymphany-da25bg08-04-1-aluminum-dome-tweeter-4-ohm--264-1458MOQ of 1,000...
PE has a TON of Peerless by Tymphany drivers currently at wholesale pricing (and associated MOQ)... Wonder what gives?
Notice the woofers that look like KEF Blade woofers? I hope they dig a bit deeper....
The DA25's they've had are still available, but they're a different impedance than those in the MOQ entries.
I think they are just like that of the MOQ TB stock. TB requests PE stock up a certain number, and therefore PE can't order until they order that quantity. This is more for their prestige lineup than the new stuff, as the new stuff is in higher demand and lower MOQs for those possibly exist. This is why you see TB items for so long at PE, as they just sell/deplete the stock they originally purchased. If the demand is high enough, changes due to market like that of NeFeB can influence special batches or reorders, or just a reorder of the previous. I was told one time that a lot of TB MOQ for PE is in the 1k pieces range.
...or the Spanish Inquisition!!
F6?
The Gradient Axis 7" is close to 90db, as well - I might be persuaded to sell my pair pretty cheap. It doesn't have the Xmax of the others, I believe they advertise 4.5mm, but it arguably has a better motor than the RS180 otherwise.
JR single driver, I'm trying to see what's out there near 90 dB per driver. I can read specs like everyone else but was wondering if anyone had used something they liked.
I'm using the Rival CPs in my current build. The 7-inch woofers are for this project:
SB17MFC35-4
https://www.madisoundspeakerstore.com/approx-6-7-woofers-sb-acoustics/sb-acoustics-sb17mfc35-4-6-poly-cone-woofer/
Yeah, it's 8:00 on Friday night and I'm typing a note here...
