A couple of comments at Iowa; my OB could use more high-end air, and focus on response at 15 degrees when setting up filters. So…
thought I’d give a try matching the bottom-end Beymas (2x12s) with a Celestion (6.5) concentric coax on my open back project. I will continue to bi-amp and use minidsp for the cross between bass and top unit (and low-shelf for low-end), but will be building filters for the coax after measuring. Looking at implementing a notch filter to address the rise in the mid around 4800 and let it roll-off and then see what options I may have for the tweeter (compression horn driver). I'd like to get away with a notch filter only on the mid, and fitting slope order of the tweeter (as presented in an old David Weems speaker design book) as high as possible (but may need a LP on the mids as well).
A couple days building OB units, guessing weeks on the filters… If anyone has had success / experience with this mid-tw filter setup all suggestions welcome.
Andy
BTW found a good source on line for ¼ self -adhesive felt (12x12) sqrs...
https://www.zoro.com/zoro-select-felt-sheet-f26n-14-in-t-12-x-12-in-2huv7/i/G2002524/
