screws, yeah screws - 'specially the haids
Guys, I built these little desktop speakers with a Gradient Audio 4 inch and a Neo3.
Everyday I look at them the the darn pan haids on the screws just chaps my, well you get the idea.
What choices do I have for a wood screw. I'd really like them to be low profile.
  • Try #4s.  This is #6 on the tweeter and #4 on the midwoofer
  • Try some Robertson head "trim screws". The heads are less than a quarter inch in diameter and are of the flush variety. They only stick up a little when installed. They only come in 1.5" length, and some have an unthreaded shank just below the head. Get ythe ones that don't have that for thinner baffles.
  • Thanks Guys   - appreciate the posts.
    The Robertson head trim screws look pretty good, thanks Wolf.
    John, smaller size would not offend my eye so much, but to tell the truth, I just can't stand those
    PE pan head screws on a finished build. Someone made the suggestion in a thread somewhere to
    look at gun blue to dye bright screws dark blue. That is probably what I"ll investigate.
    Last choice (which I might do anyways) is to use the low profile socket heads and threaded inserts.
    That's close the look I want anyways. Low profile.
    Thanks again.
  • PE doesn't sell #4s.  :)  I've done flat head but didn't find any pictures
  • You could use t-nuts or just tap the front panel if the material is rigid enough. Baltic Birch or polymer baffle holds the thread quite nicely.
    JasonP
    Thanks yeah, I'm going to give those a try. I won't know until I use them. I pretty much standardized on baltic birch, but will probably use threaded inserts.
  • Whatever you do, avoid the PE socket cap head black oxide "wood screws". The regular panheads are good, the rest are absolute shit.
    rjj45R-Carpenter
    Ask me how I know , the head on the socket cap screws seem to be made out of melted down soda cans. I wouldnt even give these away to someone.
    agreed. non-standard metric socket size also, and non-deep threads. Losers in every way.
  • Button head screws are lower profile than the standard round or pan head screws. The head is a little larger in diameter than the equivalent round/pan head but sit about half as much flatter. I like the appearance better. The socket head screws Roman linked to look better, too. I've used both and choose when I want subtle or pronounced. The pan heads always seem to look out of place. :)
    McMaster carries them.
    powered by beer
  • edited October 2018
    It's a trip that you focused on oval head screws. The more that I browsed all sorts of screws, the more that I knew that oval heads were exactly what I wanted. I could only find oval head wood screws in stainless (bright chrome finish). I've bought some gun blue to try to turn them dark blue. If that doesn't work out, I'll manually apply satin black after install. Think this is what I think will "satisfy my eyes". https://www.amazon.com/gp/product/B075DJQGWD/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  • Check to see if the bluing solution works on stainless, most don't. If you're not familiar, Brownells sells a lot of chemicals for coloring metals.
    But you might just have to paint them.
    Should look good tho.
    powered by beer
  • I was wondering the same thing...
  • We plate and coat/bake a lot of fasteners for aerospace and the military.  Some very interesting looking fasteners to say the least.  I've always got my eyes open looking for some that would work for DIY speakers...  non thus far.
  • Coating sst can be very difficult.
  • Why am I awake at 5:26AM talking about screws?
  • The only method that I know of for making stainless steel black, other than painting of course, is to first nickel strike it then plate it with zinc/black.  We do this but not very often.  This works for 18-8, 304, and 316 stainless steel alloys.
  • Ok, I'll plan on paint. That's what my Googling found anyways about SS and bluing. Guys want to use SS screws in guitar repair but didn't want a shiny screw ruining the visual esthetics. Answer: paint the head (haid!) or use other screws.
