Meniscus get together
Anyone gonna share comments and pictures?
«13
  • I actually didn't take a single picture. Just hanging out a drinking. It was a good time as usual. All the 3 ways were good. Craig kinison did a design with his buddy that was really good and Matt skbie had a really sweet 3 way. They bkth used dayton reference 8" woofers that when tuned a little higher absolutely provide high quality and substantial bass. Javads build with the epique driver was nice as well. Lots of great 2ways.
  • Stolen from facebook.
  • One very interesting thing from the event was the xover design contest was something i have thought for sometime now is that people seem to prefer a hotter mid and top end. This was confirmed by the xover selection votes. There was 3 xover designs. One was an off the shelf premade xover, one xover was done by online calculaters and text book math but they could listen to the speakers and tune them, the 3rd was done solely by measurements and sim no listening.
    I picked xover #2 for the best sounding and #3 as the second best and #1 as my least favorite. Mark tallied the results and will email them. I will say 2 and 3 where close.
  • For short listening tests, forward and/or bright is generally going to fare very well. One reason why contests are to be taken with a huge grain of salt.
    Gowa
  • Bright seems okay for 5 to 15 minutes and you think you hit the tweeter jack pot in clarity! Then your like crap my ears hurt....this is wrong and you tailor it back it down!
  • I will say that the stock off the shelf xover won btw. It had like 55-60% of the votes.
    dcibel
    Not surprising given they generally lack any kind of padding for tweeters, and usually result in a lot of peaking through crossover region, as well as cancellation above said region.
    BW deliberately voices their diamond series to sound like this - what a shock, lot of people comment on that tweeter presenting detail.
  • ...and, I will point out, even some hardcore DIY people have defended/rationalized the BW diamond line.
  • A few years back someone live streamed an event. That was awesome, especially for us foreigners.  ;)
  • We used to live stream MAC events. Pain, but a lot of value. Wonder if this Ankeny venue will have adequate WiFi... Hmmm....
  • There was alot of drunken banter and swearing most of the day so im not sure how much useful listening would've be had lol.
  • My goodness was he trashed! I would call him a chain-drinker. Finish - open - finish - open...
  • Sounds like my kind of guy...
    Gowa
    Who?
  • New guy named Chris. Good guy, he was trying to get everyone to lighten up and not be so serious. He told me my wife was super hot so he is okay in my book!
  • Apparently he's CraigK's friend, and he supplied all of the gear this year. It was a product name I hadn't heard of before: McCormack. Chris said it had a laid back midrange, and he was right, as I felt most of the speakers that played (even my own) to be a bit too reserved or laid back in the mids.
    Even if he is someone some people here would get along with, I felt him to be more of a disturbance during demos than anything else. He was loud, obnoxious, and pretty rude as far as activity/speech during demos generally goes. He was generally a nice guy, and okay in discussions, but just didn't have the normal attitude the rest of us as attendees typically hold ourselves to.
  • About the xover experiement..
    1 was a textbook filter purchased on-line. No padding or BSC, and the tweeter was reversed for a second order arrangement as they are typically described on the internet.
    2 was Jeff measuring only. No voicing or listening was done besides a final FR sweep.
    3 was Matt Sobie looking at spec FR curves, with no modeling, and then approximating it with standard component equations and voicing by ear.
    Really none of the 3 methods are what most of us do that have done this for awhile. Funny that Jeff and Matt came up with the exact same xover and values on the tweeter.
    I felt the mids were dipped at the xover on 2, and as such, preferred 1 to 2 for a flatter mid to high for that reason alone. Even if less BSC was employed, it's not always a bad thing in room if placement is considered. I preferred 3 over all, due to the flatter response at xover, and proper BSC being employed- at least where I was sitting. I was second to last row, and in the middle.
    This also got me thinking about hunches you can make in a design/build to get you closer to optimal without initially listening or measuring, and I did a design like that back in 2006 I called 'Pi-Phi'. I used a textbook off the shelf Dayton xover at 2kHz. I flipped the tweeter as they did being a second order. I inverted the drivers to angle the lobe upwards in a shorter tower, and used a coated-paper midbass with a 25mm textile dome. I also flush mounted the tweeter, and surface mounted the woofer to better align the voice coils and reduce the upward angle lobe. The woofer was a 4 ohm which gave more sensitivity for hopefully a better output match to the tweeter. And then I applied an approximate global BSC filter. I did not pad the tweeter IIRC. The result measured out relatively flat through the xover and then had a rising treble I couldn't account for in the hunches, but the experiment was completed with better results than I had anticipated. Another way of doing the woofer would be to use and 8 ohm woofer and the 4 ohm tap if there is one to yield some BSC.
    There certainly are a lot of things to can approximate or guess at to get you closer, but all the way there definitely requires at least some listening and/or measurements.
  • I think part of the reason the off-the-shelf model won was because of the two demo tracks that were used. It sounded hot on those tracks but not offensive in any way. After they took the score sheets, they put on a rock song and it became immediately apparent how grating that crossover was.
    It was still an interesting exercise that I enjoyed. Overall I had a great time, as it's always really relaxed at the Meniscus event. Wish I could have stayed a bit longer as things were finishing up. I didn't get to hear Chris's Wilson-ish clones.
  • If there had been a highpass of some sort on those Satori drivers, they would have sounded better. They were feeding the plate amp driven RSS210HF-8 pair with a full range signal from the Satori/Focal satellites. They sounded okay otherwise.
  • Ive heard two different Focal tweeters in the past ( I dont recall the models) They've always sounded edgy or bright to me. Maybe it was how they were implemented ? I wish I could recall the builds , its been a few years now.
    I didn't get a chance to hear these speakers but Dan said he didn't like the tweeter much. I've heard the Focal tweeter a few times and never been that impressed either. I think I remember seeing a graph somewhere showing that they had distortion issues, which could lead to the bright or edgy sound.
  • Mailed the picture disc to Bryan this morning.  Will post a few pics with comments shortly
  • Here are the Arcam CD player, McCormack RLD-1 preamp, and McCormack power amp.  I agree with the comments on the difference in sound compared to other amps.  I liked the way they sounded.
  • These were Craig K's speakers.  They use an Isobarik woofer configuration, magnet to cone, with a 5 inch spacing distance between the woofers.   They are ported out the rear, looks like at 3" ID port about 8 inch long.  They hit the low note clearly on the Royals track.  One of the best sounding speakers at the show, IMO
  • These are NavyGuy's Juggernauts.  One of the best sounding speakers at the show.   I have heard these speakers 3 times so far, once at MWAF, then at the Springboro Hampton, and now at Meniscus.  Very impressive.  I wish I could afford a pair of these tweeters!!
  • edited October 2018
    Here are the 3 crossovers used in the comparison.  There were actually 2 separate test sessions conducted.  One was performed Friday night, which I did not attend.  The other was conducted on Saturday at the hotel.  I voted for crossover #3, which was the one prepared by Matt.  I thought the #2 crossover was a little dull sounding and the #1 crossover was way too bright.   Maybe I heard wrong, but I though Mark said that crossover #1 won on Friday night only.  On Saturday, crossover #3 got the most votes, #2 was 2nd, and #1 was last.  Correct me if I am wrong.
    And this was the speaker used for the test:
  • This was Javad's high end Dayton Speaker.  Very detailed treble and midrange.  Good low frequency extension.  I asked Javad if he had made any changes since MWAF, because they sounded much better this time around.  From where I was sitting at MWAF, they had a very dark tonal balance, but now they sounded very smooth from top to bottom.
  • These were Billit's (another Bill S.) "Old Skool" speakers.  He mounted the tweeter to the midrange grill frame and then ran a small wire down the frame to the xover.  They are constructed of 1/2" material.  Excellent sound.  The aluminum cone midrange runs free on the top (no xover parts to tame breakup modes) and I could not hear any "breakup" problems (howling, etc).  I wonder why.
  • That is all I have time for today.  I'm at a hotspot and my battery is running low.  I will try to post a few more pics later this week.
    rjj45jhollanderTurn2
  • Thanks, Bill!
    I'll add that the test rig was relay driven on input, output, and ground. Ken did good work here!
  • I was really happy to be a part of this project. I'll try to do a write up on the board. I might also try to put a kit together with a circuit board. I do think it is a great engineering tool.
    JasonPPWRRYDBryan@MAC4thtryThumperTom
