So, everyone knows what a fan I am of this driver - what some may not know is exactly
why I enjoy it so much. Well, I have five samples here, and if I recall correctly, I purchased at least two of them six months after the others. I used to have more, but they went bye-bye. One I dropped, and I dissected it. Two went with a T/M I helped a buddy design. So that leaves me with five. It should be noted that sample 2 has a wrinkle in the aluminum cone.
In addition to a very linear response across the pass band, they exhibit some remarkable resistance to going to pieces when tasked with high excursions. All in all, hard to beat for under $20, and will hang with some costing 2x as much - if not more. Don't kill this model, MCM.
Not sure how useful the following two measurements are, still trying to figure out a way to measure Lex at my desk...
So take those with a huge grain of salt, preferably many grains of salt as found around the rim of a margarita glass.
Here is a 1M, SPL accurate distortion measurement I took of one a few years ago. This was in my black box entry, the dimensions of which I no longer recall and really don't care to hunt down, to be honest. Consider it a typical DIY level cabinet in size and construction.
So, hope this explains why I often nominate this driver when people are looking for a good midwoofer at a stupidly competitive price. Cross it below 2500 for exceptional performance and deal with the oddball frame size. It has better T/S and similar distortion to the A/C used in the Continuum, for example.
2. The only thing this driver is missing from being a serious competitor is a shorting ring of sorts.
3. I would buy a quad of them with those additions - I have already bought about 18 of them in the last several years as-is.
Geoff - I have an idea about this. Can you email me? jr at midwestaudioclub dot com
PS: Don't offer suggestions..........Damn! I'll figure this sucker out.
We don't really have the best relationship with the guys over there at PE.
We will be sending equipment to DIY events, and hopefully attending a few next year though
The design is using the Denovo 1.16 cubic foot knockdown cabinets from PE (I have them already built and sitting about), with two of the 55-2669 in parallel at the top front. 3" radius, 6" long port on bottom back. 1 ohm air core coil modeled in series (raises Q, helps these babies dig deep) which costs some sensitivity, but these drivers don't lack that.
That is 20 watts into 4 ohms. 3 mm RMS displacement is about 4.2mm, and while outside the driver's linear value a bit seems quiet doable given experience with this robust model.
Looks the the 55-2669/55-3669 are NLA.
Sorry to bring up the old thread. I earned myself the "I'm Not Dead Yet" badge in doing so.
Sad to see a great driver go...
