Is there any interest in this driver? This would be the same routine as the 8''. The MOQ is too high for me to order from Rival and RAD will be closing at the end of June. So, through my local connections, I found a way around it. There are three versions of this driver and this is the one I'm after. I seen the distortion number and they are stupid low. I'm guessing they will be between $50-$60 each.
It's a 4 Ohm driver with copper cap and alu ring. You know the drill.
Revc= 3.3
Ohm
Fr=
76.000 Hz
Sd= 54.000 cm²
Vas=
3.000 L
Cms=
0.68 M/N
Mms=
6.500 g
BL=
4.000 T·M
Qms=
9.600
Qes=
0.643
Qts=
0.6000
Le=
0.082 mH
SPL=
88.50 dB (2.83V/1m)
Continuous Power
= 50w (IEC 268-5)
I'm also trying to get another driver which is the same size but is Magnesium coated aluminum.
Cheers,
Leon
Answers
I just went to the RAD site and the R120s are listed, but sold out.
Did I just miss the only chance for these?
That driver has a couple of models. One has a titanium VC former and the other has a fiberglass former. I want the fiberglass one. It also comes with concave and convex dust caps. I can't make too many demands because he is doing me a favor and I don't want to bug him. I'm also working out the price with him. It looks like they will be close to $60 ea. I hope that price is acceptable, if it is not, please let me know. I tried to get them for $50, but he wouldn't go for it.
I'm told that I can get the 30 units that I asked for. Most of them sold to locals within a day, but I held some for you guys that requested them and a couple for me. Patience.
The supplier just started production on his job. This should take a few days to run. When he is close to finishing up, I should be able to grab the Alu/Ceramic drivers I requested.
