So I started exploring this idea this morning and figured I'd share it here early on with more data coming as I test it out.
So it struck me that using a set of four drivers is +6db voltage sensitive, the exact amount you lose from full baffle step. Could drivers be arranged on a baffle to compensate for baffle step without much (or any) XO adjustment? Then I fired up WinPCD, loaded in 4 woofers (two as woofers, and two as midrange) and spaced them out vertically. I clicked on the polar plots and here is what I was able to come up with by playing with different spacings:
The red line is the on-axis output of the quad of drivers, and the black line is the averaged hemispherical output. Does that difference look familiar? Sort of the opposite of baffle step.
So the real test will be in the listening, as the first arrival response isn't impacted, just the power response. I'm imagining that ultimately a small slope will still be needed but much less than what you might expect from normal baffle step compensation.
More to come soon!
Really, really love the bass. My working threory is that the mutlple vertical woofers excite and smooth out room modes. You are right, you don't need as much BSC.
Also could you elaborate +6db voltage sensitivity.
+6db voltage sensitivity is from the 4 drivers in parallel/series. Same impedance, but 4x the surface area increases sensitivity. Also an increase in apparent vas is evident.
