So here we have the beginnings of what essentially amounts to a "use that shit already" build. The woofer is an unknown beyond the T/S parameters - but it is attractive as far as yellow cones go. Here is a picture of them:
https://www.amazon.com/DROK-Subwoofer-Sensitivity-Loudspeaker-Component/dp/B01N76JL25/ref=sr_1_12?ie=UTF8&qid=1519866370&sr=8-12&keywords=drok+wooferThe ad copy cracks me up, you can't make this shit up:
Impedance:4 ohms; Rated power:35W; Unit diameter:6.5 inches; Sensitivity:88dB.
The speaker cone is made from imported fiberglass to provide high sensitivity and good rigidity of sound.
Adopt high performance ferrite giant magnet to promise sweet alto voice and strong bass compensation.
Bright yellow color demonstrates prime and luxury, drawing more attention.
Note: price for only a single speaker, NOT a pair, you may order 2pcs together if you need a pair of speakers.
So here is what the free-air impedance looks like:
T/S taken after a really fun break-in period:
Fs = 54.60 Hz
Re = 3.64 ohms[dc]
Le = 228.00 uH
L2 = 421.96 uH
R2 = 15.94 ohms
Qt = 0.51
Qes = 0.60
Qms = 3.41
Mms = 16.40 grams
Rms = 1.649932 kg/s
Cms = 0.000518 m/N
Vas = 12.04 liters
Sd= 128.68 cm^2
Bl = 5.849851 Tm
ETA = 0.31 %
Lp(2.83V/1m) = 90.51 dB
Added Mass Method:
Added mass = 25.00 grams
Diameter= 12.80 cm
Other than a blip at 650 or so, it looks fairly smooth enough. Models so-so in a medium vented box (0.49L) tuned to 52 Hz:
F3/6/10 of 57/46/38. Not going to really drive the point home the brontosaur stampede in Peter Jackson's "King Kong", but decent enough all things considered.
Here it is in the box with the Dayton waveguide:
Project #3 in these cabinets. At this time, they will be retired and given to someone else to put in their garage or something.
Anyways, there ya have it - back to my roots by taking a chance on an unknown driver. In all honesty, this driver should probably cost somewhere south of the Dayton classic - but it is better than I expected. I have bought probably 200+ buyout/unknown drivers in the last 10 or so years - the vast majority have T/S parameters that don't measure up to this guy. If the Fs was lower, it would be a pretty damn nice acoustic suspension woofer. As it is, it should be ok.
Wifey has dibs on the living room tonight, so hopefully measure tomorrow.
some guy managed to!
I see Amazon offers “expert setup” if you need it..
Tweeter should be a piece of cake if there are no glaring off-axis issues due to the offset location on the baffle.
No measurements yet - wife and I decided to have a date night instead.
Raw frequency response in-box:
The weirdness around 600 is high-probability real - there is a wrinkle in the impedance there as well, both free-air (as seen above) and in-box, as seen below:
An hour with Xsim yielded this:
I might throw these components together and see how it measures up and how it sounds.
So far, so good. I think the woofer is a prime candidate for some modifications to see if that blippydidodah around 600Hz can be improved.
The tweeter seemed to really like the notch, will probably keep it right there. Depending on how loud you will want to play it, it can probably safely be crossed as low as 2K IMO. Think a 4" based 2-way. As can be seen here, I am currently at about 2.5K.
Anyways, not a cheap crossover really - but I have something like 1000 components that need to be used up so I don't really care about that shit. If this was something I was designing to try and pander to the kit crowd - I might do something different, I suppose.
Pretty close to true point-to-point, very arguable on whether that has any merits, and uses some pretty inexpensive components. They all measured within 3% of advertised. The coils are both Dayton, mylar TI caps for the two larger values, and a HiVi branded MPT out of that HiVi kit I wasted my money on. Resistors are marketed by Rival. All 16awg wiring, color coded zippie ties.
If they are not sold off by Iowa, I'll bring 'em along. Thus endeth the Cabrini Redux cabinet journey. These cabinets have thousands of miles on them.
DJ Dado peaking at 105db or so, these are totally solid.
Craig, you did an MTM with the 2669 and this tweeter, correct?
