Nick will, I am sure, chime in with more information on his thought process putting the drivers together and his plans on finishing and how both aspects gave rise to the name.
Here is the unfinished cabinet:
Using this woofer:
And this tweeter:
Here are the in-box measurements (small cabinets are a pain):
Here are impedance profiles of both speakers overlaid (good consistency):
Here is the measured on-axis and reverse null:
Here are horizontals (I bet you can figure out why I left that broad "BBC Dip" in there):
Here is the crossover (note reverse polarity):
Picture of finished crossovers (I found black hot glue - yay me!):
Brief summary: the bass from the Eton is pretty legitimate, the tweeter has a very nice, sparkly sound - at first I thought it might prove to be fatiguing, but on certain test tracks I use for ssssssibilance torture they did just fine. Overall, they perform very well for a small bookshelf.
Cheap, no name drivers beaten into submission for the sake of the music.
Last year at MWAF we spent an extra day the Air Force Museum in Dayton. Lot's of old and new aircraft, including several P51 variants. I was able to show my wife all the McDonnell Douglas aircraft and missiles I had been around and worked with (not the Stealth bomber however).
Yeah, 20 years ago this would have been a pretty high end build.
One of these.
He went through Winter War and Great War. Started a Sgt. and finished, Lieutenant.
We could have a friendly speaker shootout,
Mr.Shturmovik?
https://en.wikipedia.org/wiki/PM_M1910
I know it wasn't the intent here, but I've seen that question literally start wars on modelling forums before ...
That said, left can as base coat then a *very* brief light misting of the right can should do the trick. ... or ... Depending on how far into "challenge accepted" territory you want to go it is possible to spray really fast with both at the same time so the colors will mix on the surface they are applied to ( assuming they are both acrylic or both enamel; acrylic + enamel gets messy real fast ).
Definitely between the two if this image is color accurate at all.
Here ya go. Halfway down page 2. The yellow is RLM 04. If you scroll all the way down to page 9 the shade of yellow in the diagram looks to be closest to your krylon can.
On the synergy horn I got a bit of bleed through with the the Frog tape but was able to clean it up with an artist brush.
