I'm thinking about building a 3-way floor standing tower speaker and wanted to get opinions on my proposed drivers I'm thinking about.
Tweeter = Hipuphon OW1
Mid-range = Scan-Speak 15W/4524T02 (Limited Edition model; Fiberglass cone, Titanium VC former, copper cap and aluminum ring 5.2mm X-max)
Woofer = SB Acoustics SB29NRX75-6
I'm thinking crossover points at 200 Hz & 2.5 kHz. I would place the woofer center-line about 12 inches from the floor to capture some of the floor gain. The enclosure would have tapered sides; wide at the bottom and narrow at the top to improving imaging of the Tweeter and mid-range.the Crossover at 200 Hz would be a MiniDSP and the Crossover at 2.5 kHz would be Passive - So two amplifiers needed per speaker.
So what do we think?
The mid looks more like a woofer with some work to get to 2.5KHz
Dan
Like....
Dayton Audio RS150P
SB Acoustic SB15NRXC-30
Tang Band W5-1685
Peerless NE149W
Aurum Cantus AC120/50CK
Satori MW13P or MR13P-4
Shawn
Dan
You could do that, but not sure why you would want/need to. The MW13P will play cleanly down to tuning frequency at an reasonable level. Even pushed hard, it doesn't have significant audible issues. Your baffle can be as slim as 6.25" with one facing forward. If you are going side mounted as a woofer only, I'd go with a larger woofer though, since the cabinet depth is usually less of a concern for most people than the width.
Or am I misunderstanding you and you are wanting to cross it to a side mounted woofer? If that is the case, then there is no need to worry about the crossover frequency on MW13P. The MR13P might be a different story. I don't know where it would be comfortable.
And MW16P-8
