I'm trying to get a 3 way done in time for Grinnell but the driver cutouts and rebates are chewing up lots of time. These will be ported. What I propose is to get one speakers drivers mounted so I can measure them with un-stuffed boxes and without the port installed. That way I can get the crossover designed and parts ordered. My assumption is that it matters not whether I measure them with our without the port because it will only affect frequencies well away from the crossover points. I am correct about that?
As for the stuffing, without the stuffing you should see a strong null in the midbass which can be annoying, so I've tossed a throw pillow in behind the speaker to avoid the reflection. Cramming some stuffing in there doesn't really take much time either, but it is messier than the pillow.
I do find it useful to mesaure without stuffing so you know where the rear wave reflection appears in the response, to make sure it is completely squashed when you finish the speaker.
That's the rub. Your FF measurement starts to bounce up and down below 400Hz due to room reflections. Hence the need to merge NF and FF in an attempt to get a better picture of the SPL level in the 100 to 200Hz region. The NF measurement needs to be adjusted for baffle step so that when you attempt to merge it with the FF, the slopes match up over an extended range of frequencies. But the FF measurement is bouncing up and down below 400 Hz, so the merging process is at best a good guess created by striking a line through the center of the FF's bouncing response.
I think there's a rich tradition of soldering parts in the hotel room.
Crossover sim comparing ported vs sealed FR using crossover designed using sealed measurements
Ported FR FF, NF, Port, and simmed diffraction
Sealed FR FF, NF and simmed diffraction
