New project for IowaDIY using the Peerless HDS-P830875 and Dayton ES25NdXP-4.  The box is going to be about .5 cf tuned to 50 hz and matching the knockdown box from PE that is 8.5 x 16 x 11.  The center of the tweeter is 4 inches from the top and the woofer is 10.5 inches from the top.  The sim XO is about 1.5k to 1.8k with 3rd order on the woofer and 4th order on the tweeter.
My OmniMic has been having software issues with windows 10 but I believe I was able to capture some good files.  I am going to attach the ZMAs, FRDs, and PCD files so if other would like to play around.  The FRDs have the blended response and were measured at 96 kbits from 24 inches on a mock up baffle matching my final measurements.
Here are the measured parameters.
On the crossover: Listen to that as it is, and then listen to it with a 1-2 ohm padding resistor on the tweeter shunt inductor. I'm seeing ringing at ~1.5k in that filter. It may or not be audible.
