High end midwoofer, woven cone, bigass copper sleeve on motor, bigass motor in general. Good T/S for small vented with moderate extension - more of a cross between a pure midrange and a midwoofer rather than being optimally designed for one or the other. The F3 fanatics will probably shit themselves because it won't model to a F3 of 9Hz in a pop bottle sized enclosure - but that is their problem, not mine.
Impedance curve shows a very powerful motor - Zmax is close to 120 ohms at Fs. Not bad at all. Minor inductance rise indicates the copper is doing its thang. Fairly smooth, as well, indication of a breakup centered around 5K, probably limits the "no compromise" crossover point to 2500 or so.
T/S parameters (broken in by hand):
Loudspeaker parameters:
Fs = 65.66 Hz
Re = 6.22 ohms[dc]
Le = 62.49 uH
L2 = 385.49 uH
R2 = 3.22 ohms
Qt = 0.44
Qes = 0.46
Qms = 8.34
Mms = 13.05 grams
Rms = 0.645704 kg/s
Cms = 0.000450 m/N
Vas = 5.71 liters
Sd= 95.03 cm^2
Bl = 8.501228 Tm
ETA = 0.34 %
Lp(2.83V/1m) = 88.45 dB
Added Mass Method:
Added mass = 25.00 grams
Diameter= 11.00 cm
Looks to be a nomex spider, not raised all that far but still servicable. Nice vent out backplate plus gobs of ventilation under spider and around voice coil. Should operate pretty efficiently under duress.
Really, really, really good looking driver.
My guess is they are built at same build house as Wavecor, and are likely utilizing a lot of the core concepts used on the Wavecor stuff. This is a good thing.
I don't the pricing on their website.
HTh
Jim
