I traded some CNC work for these book matched walnut slabs 1 3/16 thick But I'm not sure that I want to do all this work with these drivers. I have heard mixed reviews on the aluminum dome mid especially. Maybe I could build it and then give it to one of you crossover specialists for a year or two. The drivers will be rear mounted but mid and tweet will have spacer rings behind them so that their flanges will only be 3/16 or so back from the front face of the solid wood baffle. The slabs are 11 to 12 wide at their narrowest point and 7 feet long but I plan to cut them to about 4 feet. Come on with Ideas.
Do it.
My first thought, sorry not as a speaker, but those would make (cutting one side, keeping the facing edge raw) for an interesting floating wall shelf (or two).
Of concern, Eggman, is that the AMT in the image maybe is more of a high midrange and does not play all the way up. JohnH used it with a supertweeter.
Don't listen to the whining over the metal mid. I built an RS28A-RS52-HiVi F8 3-way years ago and it is still in rotation with no plans for teardown.
