New - Matched Pair - Dayton Audio - Carbon Fiber M/T combo . . .
edited January 2025 in Related
These are very interesting to me so I bought a pair (awaiting delivery).
https://www.parts-express.com/Dayton-Audio-CFCOMBO-4MP-3-4and-2-Carbon-Fiber-Tweeter-Mid-Combo-Matched-Sets-4-Ohm-285-412
Less than 1/2 the price of the Morel M/T combo - TM4055-8.
Following are the published particulars.
3/4" CF Tweeter:
2" CF Mid-Dome:
Thoughts/Observations solicited.
(Edited 1-11-2025 to add info links)
tktran
  • I think 600 and 3k look great as far as HD and polars go.
  • edited January 2025
    Hi Steve,
    Have you chosen your woofers?
    Exact crossover points depend on CTC distance, how dynamic (short term maximum SPL) your goals are (usually dictated by woofers)
    I would choose 4K for the tweeter, 1KH for the 2” dome and look for a pair of 7-9”‘ woofers that meets your SPL/extension targets. Getting a 10+” to play cleanly past 1KHz is a bit tougher…
    If you end up choosing a smaller or single woofer, you can relax the requirements for the 2” and 3/4” domes, lower XO points can be used…
  • Thanh, I have several Woofers to choose from (insane collection getting larger . . .) but the SS18W/8531G00 pair I have possess excellent roll-off on both ends and sound natural so I think those will be best for this combo/nearfield project (< 2m) - SPL will be pretty tame as they will be for checking mixes as a FLAT Studio Monitor in addition to my primary mixing standard headphones (SSA-VSX system).
    I plan to also build mid (>2m, <4m) and far-field (>4m) monitors which is why I have been collecting & testing mid-domes of recent.
    The 5" B&W FST mids you graciously assisted me with obtaining will probably get introduced in one of those future builds - most likely the far-field units as domes seem best used in the near-field and cones in the far . . .
    Each type will be DSP/Active so all suggested XO's will be tried and whoever comes up with a passive circuit later which makes my ears and measurement mics happy will likely get adopted for the ease of portability/swapping-out.
  • How do we get rid of that Z ripple at 8KHz on the Mid Dome?
    Zoebel?
  • I was considering buying them yesterday so I did a passive XO with VCad. I came up with 4K 4th ord. acoustic. I was disappointed that I needed so many parts to deal with mid break ups and tweeter wonky impedance. I did get a nice deep and symmetrical reverse null however. I will be interested in your listening impressions of those ridged domes. It seems to me that suppressing that mid ringing at 8-12K is of primary concern.
  • Monsieur Oeuf,
    Looking at this little schematic as an eggsample, could you please place a 4.3 uf capacitor in series with a 3.75 Ohm resistor across the Mid-dome's terminals after the XO circuit and tell us what happens to the Z ripple/FR prediction in VituixCad, S'il vous plaît?
    Merci d'avance.
  • Here it is with 8.2 uf and 4 Ohms
  • Merci beaucoup mon ami
  • Now that you've got a Zobel, don't forget your L-Pad.
    Getting ahead of the process ^ PWRRYD. (you are of course, ultimately correct).
    We need to kill the Z issue/peak electrically on the mid-dome then break in the T/M combo, apply the electrical filter, then using DSP via 3 discrete amps find the appropriate SPL levels for the chosen cabinet alignment before choosing the electrical L-Pads for the M/T, Oui?
    (edited to remove repeated repeated word)
  • From the Notes in data package:
    M/T FR w/Passive XO attempt #1 tonight using 15* off-axis FRD & ZMA data:
    Mid & Tweet:
    Took more than just a Zobel (needed a notch or something cool-sounding, like that):
    Try it out on your modelling system - phase looks OK to me but I will scrape off all the warts using DSP/PEQ . . .
    And then added . . . Obligatory Fallopian polarity & Impedance graphs:
  • I cant remember how you intend to power these speakers. A two channel amp per speaker? active XO 600 Hz and passive XO at 3K ?
    I haven't quite decided the specifics as I became hyper-focused upon killing that peak at 8KHz then went XO happy with my success so what you suggest is quite likely - just need to decide upon the actual woofers to be employed - going active XO at ~ 600Hz would afford a lot of flexibility and just PEQ'ing the M/T combo would be sweet as well.
    I do Have a MiniDSP 2X4HD sleeping in a box and a pair of FX Audio FX-502A amps next to them for a rainy day . . .
    How would you use these drivers if you were to obtain a set?
  • I must confess that my reason was mostly aesthetic. The hexagonal perforated grills matched my woofers on the shelf. I was considering going all passive, Three way or 3 1/2 way. I will try your XO on Vcad. I notice the tweeter is contributing to the overall response at its Fs. Might sound icky
  • Also, don't forget, I am still a new guy.
  • I am nowhere as experienced at this stuff as you guys and far less interested in passives - they are maddening at times - fickle, arbitrary and lack surgical precision unlike DSP although some problems with drivers must be mitigated electrically as JR and Wolf are quite adamant about - I get it, I just dislike the effort/frustration doing it with passives.
    Concerning the tweeter and Fs - only listening will tell and these squiggly lines can't let me listen to them.
    Let us know what you come up with, Sir.
    Best!
  • Scroll down this page and see if it gives you any ideas for covering less expensive drivers to match your desired "hexagonal perforated grills":
    https://www.amazon.com/metal-speaker-grill-material/s?k=metal+speaker+grill+material
    https://www.madisoundspeakerstore.com/tweeters/lpg-25nfa-1-textile-dome-tweeter/
    ^ This is my back-up to the CF tweeter due to its wonky FR above 14KHz and it has hexagonal grille holes, Eggie . . .
  • I would highly recomend using the circuit blocks if you are new to corossover design. Here is the stock 2nd order crossover set to 3k .5q. I only added C1 to tank the breakup in the mid.
  • Very much appreciate your chiming-in and effort here, Ken.
    Thanks!
    (Good help is hard to find . . .)
    Steve,
    Please please me a PM with your measurements in a zip file, and we can work through this together.
    (I’m been all active since only 2020)
  • Now you be gettin some where.
  • Sorry, I don't know any French words
  • I'm 99% sure that "gettin" is French.
    Steve_LeeEggguy
    OK, after more modeling it looks like the 8" MCM 55-5670 Woofer w/ DSP in 14L is what I need to use as the mid-woofers . . . gonna be a tight fit in the rack . . .
